Running rich
Results 1 to 5 of 5
Thread: Running rich
    My First Supra suprapokemon's Avatar
    Mar 2014
    Kingsport Tn.
    83
    Running rich
    I just got done with a engine swap on my 82 p-type I put the 5mge from my 83 in it and I upgraded my intake to a 85 with the D ports. I knocked out the freeze plug and plummed in my IAC valve so my car will idle I know the engine didn't run rich in my other car and I used the 83 injectors and fuel rail plus regulator. I did have to remove my TPS from the 82 intake to the 85 how do I set the TPS and could it cause my engine to run rich and not want to idle well when cold?
  3. #2
    Mar 2005
    Santa Cruz, Ca. 95061
    3,885
    This is a bit confusing. More details about what you swapped in. I guess you played with the ISCV-----not the IAC, whatever that is.
    You probably should have swapped the 82 throttle body over, not just the TPS
  4. #3
    Mar 2014
    Kingsport Tn.
    83
    Same this I Idle A air C control and I just spelt out valve so IAC valve same as the iscv
  6. #4
    May 2005
    N. Seattle.
    4,284
    You may have a temp sensor that is WAY out of specs or corroded contacts or is disconnected.
    The ECU takes readings of what up with the engine when warm or cold.
    I wonder if the '82 ECU is not happy with the '83 engine controls. Including the '85 TPS.!!!!!
    BTW,all of cars run on the rich side and that's a good thing.
    Franken KAR.
  7. #5
    Mar 2014
    Kingsport Tn.
    83
    The problem was all my computer. I had it loose because I was doing some wiring above it and I didn't know it grounded threw the base and I left it loose for a couple days while drive so it shorted it's self out. Put a new one in and is perfectly fine now.
