Running rich
Results 1 to 5 of 5
Thread: Running rich
    My First Supra suprapokemon's Avatar
    Mar 2014
    Kingsport Tn.
    81
    Running rich
    I just got done with a engine swap on my 82 p-type I put the 5mge from my 83 in it and I upgraded my intake to a 85 with the D ports. I knocked out the freeze plug and plummed in my IAC valve so my car will idle I know the engine didn't run rich in my other car and I used the 83 injectors and fuel rail plus regulator. I did have to remove my TPS from the 82 intake to the 85 how do I set the TPS and could it cause my engine to run rich and not want to idle well when cold?
    CelicaSupra.com Member supkar's Avatar
    Mar 2005
    Santa Cruz, Ca. 95061
    3,863
    This is a bit confusing. More details about what you swapped in. I guess you played with the ISCV-----not the IAC, whatever that is.
    You probably should have swapped the 82 throttle body over, not just the TPS
    83-Red P-type , 6M,. LJM strut-bar, RC intake,Thorley header,Tenzo 17" wheels, cross-drilled rotors, Eibach springs, KYB shocks, 85 hatch and int., 82 header panel=Frankenkar
    87 4 Runner, White, 22RE, 302K on original motor, still strong
    "This car is so loud , I heard you before I saw you!" said the nice policeman. Hidden Content
    Mar 2014
    Kingsport Tn.
    81
    Same this I Idle A air C control and I just spelt out valve so IAC valve same as the iscv
  5. #4
    4,176
    You may have a temp sensor that is WAY out of specs or corroded contacts or is disconnected.
    The ECU takes readings of what up with the engine when warm or cold.
    I wonder if the '82 ECU is not happy with the '83 engine controls. Including the '85 TPS.!!!!!
    BTW,all of cars run on the rich side and that's a good thing.
    Franken KAR.
  6. #5
    Mar 2014
    Kingsport Tn.
    81
    The problem was all my computer. I had it loose because I was doing some wiring above it and I didn't know it grounded threw the base and I left it loose for a couple days while drive so it shorted it's self out. Put a new one in and is perfectly fine now.
