7mgte Parts + 5mge ECU
Results 1 to 10 of 10
    CelicaSupra.com Member
    Aug 2005
    Trussville, Al
    484
    Hello everyone. I've been unemployed for about 7 months now and decided to try and make a little money by selling parts I no longer need. From what I can tell by looking on Ebay, etc, these items are priced below the going rate. Everything I am selling is in good shape and good working order unless noted. I also have a stock JDM 7mgte long block with probably around 80K miles on it that started using oil. Pics on request.
    7mgte long block (uses oil) $200
    7mgte OEM fuel pump (removed after 68K miles) $25
    7mgte oil pan (no dents) $45
    (2) 7mgte ECU for manual trans $35 each or 2 for $50
    OEM CT26 turbo shields (all 3) $40 SOLD
    7mgte CT26 turbo w/60 trim (blowing oil - needs new seals) $115 SOLD
    Lipp open exhaust elbow for CT26 $70 SOLD
    Lexus AFM upgrade $60
    (2) OEM 7mgte exhaust manifolds $25 each
    7mgte Toyota OEM blow off valve (was only used about 6 months) $15
    5mge ECU for manual trans $25
    5mge OEM Toyota radiator cap (used about 8 months) $10
    MSD Tach Adapter Model 8920 $30
  3. #2
    CelicaSupra.com Member Zerodrag's Avatar
    SoCA
    384
    What is the serial code of this ECU?
    Thanks
  4. #3
    Aug 2005
    Trussville, Al
    484
    I should have mentioned it's for an 84 P type. There are two numbers on it so I will give you both.
    5M-GE M/T
    89661-14020
    175000-0152 12V
  6. #4
    Nov 2012
    SoCali
    344
    Can you post pics of the turbo shields (all three)? TIA,
    Ken.
    1985 Toyota P-Type Celica Supra 5MT
    1993.5 Toyota Supra Turbo; 1994 Toyota Supra Turbo; 1995 Toyota Supra Turbo
    1991 Toyota Supra Turbo; 2006 Toyota 4Runner Limited V8
    2010 Lexus IS-F
    2016 Lexus IS 350 F Sport
  7. #5
    Aug 2005
    Trussville, Al
    484
    Turbo shields sold.
  8. #6
    Nov 2012
    SoCali
    344
    Keith,
    Thanks for the pics. Much appreciated. PM sent.
    Ken.
    2010 Lexus IS-F
  9. #7
    Junior Member
    Feb 2005
    Escondido, CA
    24
    Do you have pictures of the LIPP turbo elbow?
    Hard Tuned Motorsports
  10. #8
    Aug 2005
    Trussville, Al
    484
    Quote Originally Posted by SD2JZA70 View Post
    Here is a side view.
    http://s221.photobucket.com/user/kps...tml?sort=3&o=1
  11. #9
    Junior Member
    Feb 2005
    Escondido, CA
    24
    I'll take it. Sent you a PM
  12. #10
    Junior Member
    Jul 2016
    simi valley
    13
    Still have the ecu sir? Text me if so. 805. 387. 4446
