Piston ring end-gaps too large - Page 2
Results 11 to 20 of 20
    CelicaSupra.com Member Khlause's Avatar
    Tacoma
    409
    I have a great (HORRIBLE) idea.
    File all the ring gaps to the large size so they match
    Do the same for the oil rings (to their max size)
    Get some low compression pistons out of an old 82 / 83 5M
    Now add 24 to 30LBS of boost; now your ring gaps will narrow up but not get too tight.
    See clearly a bad idea to tighten up the ring gaps.
    CelicaSupra.com Member SupraMoto's Avatar
    Victoria, B.C. Canada
    256
    It settled then ! .....that's what I'll do. lol jk
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
    256
    I'll get the Enginetech C83016 Premium Steel top rings and hopefully they're better.
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  6. #14
    256
    scratch that - I'm going with Hastings rings
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  7. #15
    256
    Quote Originally Posted by Juka View Post
    I've ordered lots of parts from RockAuto and been very happy with their quality and prices. There were however a couple of times that I received incorrectly packaged parts from them - the part inside the box was not what was labelled on the box.
    Damn Rockauto just screwed me again, my main bearings were packaged incorrectly. All 14 pieces had the oil groove & oil holes. It should've had 7 of the pieces flat (no oil groove/holes).
    like these
    I was over the 30 day return period........ so the website wouldnt let me return....... called then they agreed to re-ship them, and at first wanted me to return the defective part at my own cost, then agreed that I dont have to ship back the defective part. Not bad in the end, but annoying
    The moral of the story is to carefully inspect your order as soon as it arrives.
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  8. #16
    14,684
    Actually, most builders prefer all bearing shells to have the groove. You got lucky and got that without having to buy 2 sets of mains. Up to you how you want to assemble it though. Rock auto doesnt pack the bearings however. They should have all been vacuum sealed to a cardboard backing in the package.
    Hidden Content black 84 7mgte, MS2, truetrac, bbk, etc...soon to have 2jzgte and t56
    Hidden Content blue 85 beater
    Hidden Content black 86 triple weber 6m in the works!
  9. #17
    256
    Oil grooves in both halves of the bearing ?!?! I didn't realize that was even a possibility. I thought the lower bearing half was always flat/smooth because that's the loaded side of the bearing.
    Your right, it wasn't Rockauto's fault, the manufacturer packaged these wrong. Rockauto will take this matter up with the manufacturer if they feel so inclined.
    The box came with two sets of 7 bearing halves each vacuum sealed separately, and thus the possibility for packaging mistakes. These were EngineTech BTW.
    I'm holding my breath that the new set is correct.
    If I'm lucky the new set will totally without grooves, and I can assemble 2 full sets with both.
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  10. #18
    1,190
    I don't know if full race main bearings are still fully grooved on both halves. But they certainly were from the 60's to the 80's. This was for various flavors of NASCAR motors. The bottom half being solid for load bearing does make sense though, which is probably why most engines don't use fully grooved mains. My understanding was that the full grooves helped in keeping sufficient oil to the rod bearings. But this was back when the best racing oils all still sucked. At some point they all essentially ended up becoming a wall of oil being pushed by the journal. It takes about as long to visualize that as it would last in the real world. Lucky us. Even the crappiest oils being made today are worlds better than those were!
  11. #19
    CelicaSupra.com Member drjim's Avatar
    Aug 2013
    SoCal / Long Beach
    3,116
    Fully-grooved bearings have been in and out of favor for years. A lot of it depends on the original design of the engine; bearing surface area vs bearing loading vs engine output.
    For our 5M engines, I'd go with whatever the original design was.
    1985 5-speed "Ms. Swan"
    OH, What A Feeling!
  12. #20
    256
    Well the stupid new set of bearings I received today are also full-groove. Don't think this is correct.
    I checked the manufacturer website and its pretty clear the upper and lower shells should be different. Each half shell has a unique P/N, and the picture shows half-groove.
    Shell P/N .......... Position
    M1-1051-L ........ 1-2-3-4-5-6-7
    M1-1051-U ....... 1-2-3-4-5-6-7
    Where else can I get some 0.25mm undersized main bearings ? Reasonable shipping to Canada is usually a problem.
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
