7mge swap into 82
Results 1 to 7 of 7
    CelicaSupra.com Member guido's Avatar
    May 2008
    bretagne the BZH land in france
    846
    7mge swap into 82
    I know it s documented for the ge swap , i have all the link and i all read them but my problem is the difference of wiring for the 82
    Ecu pin oit are totaly different
    Does anyone can belp me
    I am sure it already have been done
    Any help is welcome
    FUN IS NOT ON STRAIGHT
    Hidden Content
    Hidden Content
  3. #2
    May 2005
    N. Seattle.
    4,385
    Gee,it looks like all that you need is a 7M/MK III ECU and wiring spaghetti.
    The '82 ECU is WAY different.
    http://www.ebay.com/sch/i.html?_odkw...Supra&_sacat=0
  4. #3
    May 2008
    846
    So nobody that have already done the same swap to help?
    Hidden Content
    Hidden Content
  6. #4
    May 2005
    N. Seattle.
    4,385
    HEY! Go a little easy on these guys.
    We will get to your issues.
  7. #5
    May 2008
    846
    It was just a lil update , doesn t think i have been rought
    Hidden Content
    Hidden Content
  8. #6
    CelicaSupra.com Member 4SFED's Avatar
    Jul 2003
    Lake Mills, Wisconsin
    5,163
    The '82 does not have TCCS, therefore the '82 ECU controls only fuel but not spark. In 1983 Toyota introduced the Toyota Computer Control System (TCCS). TCCS controls the EFI and the ignition system (spark). I have swapped out 5me engines from older (1981) Supras that did not have TCCS with newer 5mge engines but I used the old '82 5mge distributor with vacuum advance instead of newer electronic spark advance and then also kept the older style ECU without TCCS to manage the newer 5mge that I swapped in (so that I didn't have to change out the wiring harness). So I was running a 5mge engine with a 5me ecu and wiring harness. The 7mge never had the vacuum advance option. Without vacuum advance you have to use a engine management system that controls spark in addition to fuel. So I think your best bet would be to use an aftermarket engine management system unless you have a donor car with complete 7mge and wiring harness and ecu.
    Dave Harrison
    current lineup and year acquired:
    '85 white Mark2 7mgte 5sp 1990
    '85 white Mark2 7mgte Auto 2009
    '84 maroon Mark2 6mge 5sp 2013
    '85 black Mark2 2jzge 5sp 2015
    '86 SDR Mark2 7mgte 5sp 2016
    Hidden Content Originally Posted by cheappower82 Hidden Content
    Guess you have the magic touch; touch mine please?!
  9. #7
    May 2008
    846
    It s a complete wiring harness with ecu
    Hidden Content
    Hidden Content
