Getting no spark or fuel 86 Supra
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Member
    May 2010
    Phoenix, AZ
    49
    No spark or fuel.
    Hi guys, hoping I can get some help from the 5M gurus.
    I took my 86 Ptype for a drive and it was running fine, I stalled it (I don’t drive it much and have 3 manual cars so it takes me a while to get used to the clutch on them). After that the car would not start, I get no fuel and no spark (car cranks of course). I checked all the relevant fuses.
    Any ideas?
    Thanks!
    Hidden Content
    - 1998 6speed Black/Black Genuine TRD Widebody Supra 76S turbo, Titan/Crower 3.4L Stroker with a Stage 3 Titan Street/Race Head, 19X13 and 19X10 IForged Astras with 355/25/19 and 275/30/19 Pirellis, and much more.
    - 1997 Auto Red/Tan BPU Supra
    - 2001 Sapphire Blue Viper GTS
    Borla, Fidanza, 19" CCW 505A, Eibachs, Smooth Tubes, Stereo, Navigation
    - 2005 Black RAM SRT-10 Quad Cab "Viper Truck", Magnaflow exhaust
  3. #2
    Oct 2003
    Montréal, QC
    6,564
    sometimes when you stall them, the ECU pour full in and they get wet. cranking at WOT helps. Could also have something that failed at the same time. If you have a timing light, that will check timing belt and igniter at the same time. Does the exhaust smell fuel?
    Gee that '98 looks nice!
    -Jocelyn,
    P85-5MGE SDR had 439KKm (for 17 years my daily driver, RIP...), 2002 E39 ///M5 LMB Hidden Content
    Hidden Content Hidden Content
  4. #3
    Member
    May 2010
    Phoenix, AZ
    49
    It's definitely not getting fuel, there's no fuel smell from the exhaust and the spark plugs are nice and dry. It's also not getting any spark. So whatever condition is causing this is causing no spark and no fuel.
    Any ideas?
    And thanks on my 98 Supra! I recently sold it (I regret it) but I bought a black 6speed 1997 (single turbo) with 31K miles
    Hidden Content
  6. #4
    Santa Clara & Stockton, CA
    7,547
    Do you get a CE light when the key is turned on (verify ECU is being powered)? Next I pulled the distributor cap and crank it to verify the rotor is turning. The pickup is in the distributor so if that isn't rotating the ECU won't even try.
  7. #5
    Member
    May 2010
    Phoenix, AZ
    49
    Yes on CE light. I took the cap off to verify the rotora hadn't come off but didn't crank the engine to ensure it's turning.
    I also am not getting spark from the coil (but have 12V going to the coil)
    Thanks for the reply!
    Hidden Content
  8. #6
    Oct 2003
    Montréal, QC
    6,564
    if the timibg belt broke, the rotor won't be turning => no spark & no fuel. The ECU needs rotation from the distributor to trigger both. Ensure it rotates. (broken belt did happen to me on the road)
    -Jocelyn,
  9. #7
    Vancouver, BC
    9,123
    If it's not the EFI fuse or the fusible links in the fuse box or on the black box coming off the positive battery terminal, or the main relay, then I'm guessing it's your AFM. The connector going to the afm may have come off (not uncommon if the connector is cracked or missing it's metal retainer), or perhaps the flapper in it has become jammed. The ecu will not turn on the pump or give spark till the afm reports some air flow. Given the circumstance that led to this, I'm guessing AFM.
    The ecu becoming unplugged is the only other condition that can cause this result as I recall.
    Black 86 mk2 Project Car
  10. #8
    Member
    May 2010
    Phoenix, AZ
    49
    Thanks for the ideas! AFM is possible, I have not checked it. I know it's not the timing belt as I removed a plug and cranked it without the plug in and you can clearly hear the uneven cranking.
    Thanks for the ideas, I'll have to try them!
    Hidden Content
  11. #9
    Mar 2005
    Santa Cruz, Ca. 95061
    3,924
    I was also guessing timing belt, like Red. I would crank in while observing the dist. rotor. If the rotor does not rotate, visually inspect the timing belt. If it does rotate, yeah go on to the AFM.
    Quote Originally Posted by 1998TRDWBSupra View Post
  12. #10
    Vancouver, BC
    9,123
    Don't think its the timing belt. You should still have fuel in that case. This is the ECU either not powering on, or failing a startup procedure and denying spark and fuel. Won't be a mechanical failure. 98, if my ideas don't pan out, just run through the trouble shooting section in the FSRM. It has a section specifically for this problem and the exact procedures to run through to find the problem.
