Nasty rear end vibration.
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    CelicaSupra.com Member
    Nov 2016
    USA
    155
    Bought an 82.
    Got a good deal thanks to a suspicious differential and rear end sort of wobble on acceleration.
    Pro diagnosis 1 - carrier bearing at the two piece drive shaft splice.
    Pro diagnosis 2 - took it to a drive train shop to have the bearing fixed if possible, or new driveshaft fabbed/possibly bought. He rediagnosed it as a "blowed up" diff that was improperly rebuilt, along with a bad seal that let it dry up many, many miles ago.
    Found a replacement diff and installed it. Limited slip is back in action, the wobble/vibration is worse.
    Unbalanced driveshaft? Unbolt it and rebolt it after a quarter turn until I find the original shaft to diff alignment?
    I'm totally lost.
  3. #2
    Feb 2004
    Austin, TX
    2,748
    I'm assuming you started with the basics like swapping the wheels front to back? You can disconnect the axles and rotate the wheels/hubs and check for play, that's like 4 bolts per side and easy to do. You can check the axles at the same time too.
  4. #3
    CelicaSupra.com Member tdream's Avatar
    Oct 2003
    Mesa, Arizona
    523
    Check the universal joints. If you can move the back and forth they are gone.
    Sent from my iPad using Tapatalk
  6. #4
    Nov 2016
    USA
    155
    There is play at the U joint/carrier bearing. I figured if the drive train shop said it was okay it was okay. I may try rotating the shaft relative to the diff anyway.
    Hey, I got an upgraded diff out of the deal LOL.
  7. #5
    Santa Clara & Stockton, CA
    7,504
    If it that bad just jack the rear tires of the ground and drive it slowly. It should be pretty obvious to the eye. Generally u-joint and bearings are noisy and make clunks unless they are way overdue. Usually stuff you feel in the seats is suspension and tires.
  8. #6
    Nov 2016
    USA
    155
    Is it dumb that tires/wheels hadn't even occurred to me? Hahaha
    The CVs seemed fine while I was down there unbolting/rebolting them.
  9. #7
    May 2005
    N. Seattle.
    4,418
    You may have a warped rear rotor and a dragging caliper/bent rear hub.
  10. #8
    Nov 2016
    USA
    155
    I just nuked my truck on the way home from work, so this car will be getting my full attention ASAP. I was trying to get the Supra roadworthy to avoid this, knew it was coming.
    I did notice the rear passenger side looked like someone was changing a tire and it fell off the jack...LOL/SIGH. All my 12 years of zero car problems are coming to a head right at this moment.
  11. #9
    Oct 2003
    Montréal, QC
    6,539
    ensure the front to rear shafts are attached together the following way, so is the orientation of the carrier bearing:
    http://www.cygnusx1.net/Supra/Librar....aspx?S=PR&P=6
    -Jocelyn,
    P85-5MGE SDR had 439KKm (for 17 years my daily runner, RIP...)
    2002 E39 ///M5 LMB, Hidden Content Hidden Content
  12. #10
    Nov 2016
    USA
    155
    Oooh, thank you.
