5mgte Ebay Turbo
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Junior Member
    Jan 2017
    Ontario Canada
    12
    5mgte Ebay Turbo
    Has anyone installed a 7mgte turbo kit from ebay on their 5mge?
    Would the header in the kit fit? Or is a stock 7mgte header the way to go?
    Thanks
  3. #2
    CelicaSupra.com Member 4SFED's Avatar
    Jul 2003
    Lake Mills, Wisconsin
    5,162
    what kit?
    Dave Harrison
    current lineup and year acquired:
    '85 white Mark2 7mgte 5sp 1990
    '85 white Mark2 7mgte Auto 2009
    '84 maroon Mark2 6mge 5sp 2013
    '85 black Mark2 2jzge 5sp 2015
    '86 SDR Mark2 7mgte 5sp 2016
    Hidden Content Originally Posted by cheappower82 Hidden Content
    Guess you have the magic touch; touch mine please?!
  4. #3
    Member
    Jul 2014
    Conowingo
    61
    if you decide to ebay turbo kit your car, the welded headers will crack like crazy, spend the extra $150 to grab the cast manifold for a t4 turbo. they use a 50mm wastegate that driftmotion sells. that wastegate costs $100.
  6. #4
    Junior Member
    Jan 2017
    Ontario Canada
    12
    Something like this for example: ********ebay.ca/itm/GT45-24PC-TURBO-KIT-TURBOCHARGER-MANIFOLD-INTERCOOLER-86-92-SUPRA-MK-IV-4-7M-GTE-/401253897974?hash=item5d6c9896f6:g:NLEAAOSwEzxYbFr s&vxp=mtr************
  7. #5
    Junior Member
    Jan 2017
    Ontario Canada
    12
    Thanks for the suggestion on the t4 cast.
  8. #6
    Santa Clara & Stockton, CA
    7,479
    Cast manifold is a lot easier to plumb, keeps the heat down in then engine bay, and can spool the turbo faster. Tubular looks cooler and can have more potential on crazy big setups. They can all crack though. Even the stock Toyota manifolds crack.
  9. #7
    Jul 2003
    5,162
    The 7m and the 5m exhaust manifolds have the same bolt pattern so if your kit bolts up to a 7mge or 7mgte head then it will bolt up to the 5mge just like a stock 7mgte manifold onto a 5mge. You have to cut a notch out of the 7mgte manifold where it fits next to the power steering pump bracket to fit the 5m so chances are you will need to do the same with a kit meant for the 7m. When I turbocharged a 5mge and a 6mge back in the '90s I just used the stock 7mgte manifold and CT-26 turbo but after blowing them both up I smartened up and have since been swapping in the whole 7mgte.
    Use search - your question has been asked and answered several hundred times on this forum over the years.
    Dave Harrison
  10. #8
    CelicaSupra.com Member SupraMoto's Avatar
    Apr 2003
    Victoria, B.C. Canada
    236
    Quote Originally Posted by 4SFED View Post
    I hear you say that and it makes me worry, since I'd like to go turbo eventually...... BUT it should be possible to turbo 5M's reliably / safely.
    I'm guessing that back in the 90's you weren't running standalone ECUs, which would really help for safety and reliability.
    Were you running crazy boost ???
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  11. #9
    7,479
    As they say cheap, fast, or reliable pick 2. There's no reason to say you can't make a 5MGTE reliable, its just a lot easier to plug in a 7mgte and walla have 232hp with Toyota reliability.
  12. #10
    Junior Member
    Jan 2017
    Ontario Canada
    12
    I apologize for the way I worded my question. What I was really wanting to know was whether or not there would be enough room in the engine bay for an ebay kit 7mgte header. From the way it appears in photos the header looks wider than the manifold. Maybe the turbo placement is different though so it would even out?
    Is anyone running a turbo from ebay on any of our engines? If so your thoughts on its value for your money would also be appreciated.
