Head Lights for My 83 Supra
Results 1 to 9 of 9
    Junior Member
    Feb 2017
    Hannibal, MO
    4
    I have a 1983 Supra. My headlights work but no longer go up and down. I am not a mechanic and I am not sure what to look for on this problem. What would be typically the problem and how can I fix it?
  3. #2
    Member
    Sep 2016
    Chester, Va
    32
    sounds like headlight motors have gone bad. for a temparary fix there is a way to raise and lower your headlights manually. pop your hood and look beside each headlight. you should see a rubber cap, take it off, you will then see a red knob. this knob will raise and lower your headlights. i hope i was able to help. you should be able to get your local parts store to order the headlight motors.
  4. #3
    Junior Member
    Sep 2016
    UPLAND CALIFORNIA
    4
    Quote Originally Posted by JohnRolsen View Post
    Check your fuse box for any blown fuses . I once had a problem when my headlights would only pop up when the drivers side door had to be open prior to starting the car. The problem was caused by a blown hazard fuse.
  6. #4
    Mar 2005
    Santa Cruz, Ca. 95061
    3,918
    The most common problem is the fusible link that comes from the battery. Headlight motors rarely fail and not both at the same time.
    I have used fusible links for sale . From the pos. terminal , you see a wire going to a white connector . This connector has a pink or brown wire looped into it. The wire from the battery ( about 4 ") to this connector is , itself , a fuse. Open the connector and check for power. Replace this batt. side of the connector including the fusible link if not getting power. If you're getting power through this, then check for power to the headlight retractor relay on the pass. side of the engine bay, with headlight switch on. If power is going to the retractor but not through it, then buy a used retractor relay. I have both: relays and fusible links.
  7. #5
    Junior Member
    Jan 2017
    CA
    27
    John, same problem on my '85. Thank you for posting up! I searched the forum and found that I needed to check multiple fuses and the fusible link issue.
    Supkar, I have the same issue with my '85 and have replaced the retractor relay (twice) and the links are still intact as well as my headlight fuses. Headlights and fog lights turn on, but the motors aren't getting power.
  8. #6
    May 2005
    N. Seattle.
    4,431
    Quote Originally Posted by katodragon View Post
    http://www.cygnusx1.net/Supra/Librar....aspx?S=E&P=16
    The retract relay get power from the HAZ/HORN fuse???
  9. #7
    Junior Member
    Jan 2017
    CA
    27
    You have GOT to be kidding. That's got to be one of the stupidest things I've ever seen LOL. My horn is disconnected due to it going off when I unlock the door. I'll check that fuse though...
  10. #8
    May 2005
    N. Seattle.
    4,431
    OFF TOPIC:
    Your cruise control will not work if your brake fluid is low. WTF!
    The TSRM does not show that!!!!
    I had to use a different book to find out.
  11. #9
    Junior Member
    Jan 2017
    CA
    27
    Dave, you need sleep LOL
