Ignition keeps locking up
Results 1 to 8 of 8
    Junior Member
    Jan 2017
    Modesto, Ca
    8
    Hey guys any one else ever experience this? My car keeps locking the key in the ignition where I can't turn the ignition over. It stays in locked. My tires aren't locked up and I just swapped out the whole steering column, only to have the same result! Any help is greatly appreciated
  3. #2
    Santa Clara & Stockton, CA
    7,505
    Did you try wiggling the steering wheel back and forth lightly while turning the key to take any pressure off the lock?
  4. #3
    Junior Member
    Jan 2017
    Modesto, Ca
    8
    Yeah my steering locks up, if I keep wiggling, the steering unlocks but the key doesn't
  6. #4
    CelicaSupra.com Member
    Sep 2007
    Edmonton, AB
    201
    Try spraying some lubricant in there.
    1981 Celica Supra - 5ME
    1981 Celica Supra - 5MTE
    1985 Cressida Wagon - 5MGE
    1981 Kawasaki KZ1100
    1995 GMC Jimmy
  7. #5
    Mar 2005
    Santa Cruz, Ca. 95061
    3,917
    Is it possible the key is worn out? Key code is on the pass. door tumbler. Just a thought. If lubricant does not help, you could buy a used ignition tumble with key or try having a new key cut for your existing tumbler.
  8. #6
    Junior Member
    Jan 2017
    Modesto, Ca
    8
    I swapped out the whole steering column with a new tumbler/key worked but when I turned key back to off, once again locked up
  9. #7
    Mar 2005
    3,917
    Replacing the steering column was probably not necessary. Try to find a mechanic to come over to look at it or take it to a Toyota shop if you can't fix it.
    Quote Originally Posted by Indyc89 View Post
  10. #8
    Junior Member
    Jan 2017
    Modesto, Ca
    8
    Problem solved, I junked it. Sad to let it go but it was just taking up space..
