Injector Info ! - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: Injector Info !
  1. #31
    CelicaSupra.com Member cheappower82's Avatar
    Apr 2003
    Montgomery, AL
    1,741
    Guess I have another vendor on my build list. I'm going to send them my 720's and some 440's or 550's for the break-in period/mild tune
    According to his calculator, I need to run 87% duty cycle on the 720's for 600chp......and I thought I had too much injector
    85 P-type No-JZ
    87 Volvo 245 wagon lm7+t
    04 CTS-V
    Hidden Content
  3. #32
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    12,765
    I used to use witchhunter, then they raised their rates and started hating on the candians.
    I now use this guy: http://www.cleaninjectors.com/
    His name's Tim, and he runs a tight ship. You get flow, opening time measurement, cleaned, reflowed, and all the little replaceable bits replaced for $11 each. THEN he gives you a subjective review of the flow pattern and set balance (priceless).
    I trust him 100% with my stuff and wouldn't use anyone else, and I'm an ex-witchhunter convert.
    --billyM
    White 85P - Blue/Silver 85P
    Hidden Content
    Hidden Content
  4. #33
    CelicaSupra.com Member Wolfgang's Avatar
    Sep 2004
    Vancouver BC
    552
    From another forum.. part numbers useful..
    Stock 1UZFE Injector:
    Code number: 23250-50020
    Overall Length: 2.800"
    Injector Tip Length: .260"
    Injector Inlet Length: .614"
    Injector Tip Diameter: .368"
    Injector Inlet Diameter: .415"
    Injector Opening:2
    Injector Connector: Type F
    Flow Rate: 251 cc/min
    Impedance: high 13.8 ohm
    Stock 7MGE Injector:
    Code number: 23250-70080 Light Green Tip
    Code Number: 23250-70040 Yellow Tip
    Overall Length: 2.810"
    Injector Tip Diameter: .370"
    Injector Inlet Diameter: .416"
    Injector Opening:4
    Flow Rate: 315 cc/min Light Green
    Impedance: High 13.8 ohm
    Stock 7MGE Injector (Yellow):
    Injector Opening:4
    Flow Rate: 295 cc/min Yellow Tip
    Impedance: Low
    85 Supra, Red, Auto, 300k. Chimpy 6M. MHG & ARPs. 60-1 Trim, Stainless Lines, Q45 Brakes, 16's, Al Rad+E fan, Oil kit and cooler, MSD 6a + Accel Coil ms2 3.57... Air shocks and coil overs in the works.. Maybe a mk3 trans next........
