the best thing is to jack it up as high as you can then put jack stands under it. MAKE SURE THEY ARE ON THE FRAME AND NOT THE SUBFRAME!!!! HAVING THEM ON THE SUBFRAME BOLTS WILL CAUSE IT TO FLEX AND BE A PITA TO REINSTALL THE DIFF!!!!!.
remove the 4 nuts holding each half shaft to the diff.(14mm) then remove the 4 nuts and bolts that are holding the drive shaft to the diff.(12mm)
then remove the 2 19mm nuts that are facing the rear of the car just above the sway bar. leave the 2 bolts in the holes to hold the diff when you remove the other bolts. now remove the 4 17mm bolts from the top of the diff., then remove the 4 17mm bolts on the sides of the diff.(2 on each side)
once all bolts are removed, put a jack under the diff., leave about 1in between them. pull the 2 bolts that had the 19mm nuts on them out. you will probably have to smack it with a wrench. once it jars free, lower the jack and pull it out.
for reinstallation, place it on a jack and roll it underneath lined up as best you can. jack it up into place. if it seems to catch, keep jacking it up SLOWLY, it will pop into place, once it does, be sure those 2 bolts on top line up first and slide the bolts through. you may have to hit it to knock it one way or the other, you may also have to slightly lower the jack.
once you slide those in, lower the jack from the diff and place it under the nose of the diff. slowly jack up the nose of the diff until the front side bolts line up. then put the 4 17mm bolts in on the sides. once screwed all the way in( DO NOT TIGHEN THEM YET) try putting in the 4 top 17mm bolts. if they dont quite line up, try raising the nose slightly, they should line up.(worse case scenario youll need a long peice of pipe or the handle from a hydraulic jack to slide over the metal plate on top and pry it down a bit. or you could try loosening the 2 large front subframe bolts a lil to allow it to tilt. if so dont forget to tighten them back when your finished.)
once those 4 bolts are threaded in, tighten all 8 of the 17mm bolts, then tighten the 2 19mm nuts onto the bolts coming through the top rear.
then bolt the drive shaft and half shafts back on. then jack the car back up and remove the jack stands, lower the car. guess what, your finished.
