7mgte swap FAQ - Page 28
Page 28 of 28 FirstFirst ... 18262728
Results 271 to 278 of 278
Thread: 7mgte swap FAQ
  1. #271
    CelicaSupra.com Member jdk_ii's Avatar
    Bawsten
    1,948
    Quote Originally Posted by '82supra View Post
    I did some digging and found this hidden gem ...some older members may recall Project 7mgte
    OMG, my ancient web pages from long ago.
    Jim
    MK2 Geek Squad Member
    Hidden Content
  3. #272
    Member Tanto's Avatar
    Feb 2013
    Rapid City, SD
    96
    *edit* disregard...
    William Olson
    2000 Subaru Legacy GT (Granny)
    1982 Toyota Celica-Supra (The Racecar)
    2012 Honda Ruckus (The Cost Cutter)
  4. #273
    Junior Member
    Dec 2014
    Lowell ma
    1
    Bringing this post back from the dead I'm very new to this and I just picked up a 84 Celica supra with a 7mgte in it coolant temp gauge isn't working rpm gauge isn't working any ideas
  6. #274
    May 2005
    N. Seattle.
    4,385
    Please fill in your profile so we know what car you have and the mods.
    Who did you buy this from?
    Was it a forum member?
    Off hand ,I would search the TSRM to see how to test the coolant sensor and what was installed for the
    tach adaptor,so far.Brand of ignition coil and a LOT more.
    We will not hand you the answers. You have to work for them.
    Start here:
    http://www.cygnusx1.net/Supra/Librar...3/default.aspx
    I give you 3 hours to have a look-see.
    10-4.
  7. #275
    Apr 2012
    Pensacola, Florida
    244
    In regards to a GE swap. Why can't the 84 pump and pan be used? Which fuse box do I use? And the only harness I need is the engine harness. But can the other two existing mk2 harness clips be repinned to match the 7M ecu? I'm kinda confused as this is mainly a thread for the GTE. And I'm sure I missed something in the post as it is hard for me to read everything on my phone since my internet has been turned off.
    If at first you don't succeed, call an air strike!
    1984 P Type 5MGE 5 spd, just now getting to the restoration/modification process.
  8. #276
    May 2005
    N. Seattle.
    4,385
    Quote Originally Posted by msgsupra84 View Post
    NO internet?
    Go to the local library and use theirs. Can you burn a CD rom of the TSRM? Maybe on flash drive.
    Write yourself a list and use a buddies computer?
    Run a long CAT 5 from your neighbors house?
    Use a neighbors wireless router code?
  9. #277
    CelicaSupra.com Member 4SFED's Avatar
    Jul 2003
    Lake Mills, Wisconsin
    5,163
    What 84 pump? Fuel? Oil? Water? Who says it can't? As far as oilpan is concerned, a deeper pan was used from late '84 or on '85 and newer 5MGEs so if you use the deeper oilpan you also need the matching oilpump, too.
    Use a 7mge from a Cressida - it's already front sump.
    Dave Harrison
    current lineup and year acquired:
    '85 white Mark2 7mgte 5sp 1990
    '85 white Mark2 7mgte Auto 2009
    '84 maroon Mark2 6mge 5sp 2013
    '85 black Mark2 2jzge 5sp 2015
    '86 SDR Mark2 7mgte 5sp 2016
    Hidden Content Originally Posted by cheappower82 Hidden Content
    Guess you have the magic touch; touch mine please?!
  10. #278
    Apr 2012
    Pensacola, Florida
    244
    I just saw that the 85 oil pan and pump must be used. Glad to know it will work though, wife put me on a budget for the swap at the last minute. The cressida motor is what I'd like to find, but then again, finding any 5M or 7M in my town is hopeless so I'll take what I can get.
