Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Hybrid View
    Dec 2004
    Indianapolis
    140
    Calling all 5MGE engine experts...
    I am in the middle of an engine rebuild on my 85 and I can't seem to find any good info on the 5MGE. I have done some measurements with a graduated cylinder and clay on the piston but I just wanted to check and see if anyone had these numbers or has done any measuring so we can compare numbers.
    Serviceable limit (How much material can I remove) on the Cylinder Head or Engine block? ( I have seen 0.006" for cylinder head, but that seems tiny)
    Piston Dish/Dome volume (measured about -1.5cc)
    Combustion Chamber volume (measured about 50cc)
    Factory gasket thickness (1.2mm or 0.047")
    Piston to valve clearance (measured between 0.110" exhaust and 0.105" intake and this was with a 1.4mm or 0.055" head gasket)
    These numbers are usually not that hard to find on other engines, but I guess that's what makes the 5MGE so special!
    1985 Toyota Supra
    Seattle, WA
    9,445
    Have you looked at the engine section of the online TSRM yet???
    Chris Eng
    1981 MA47 Silver Metallic 5ME Automatic
    1985 MA67 Super Deep Red 5MGE 5-speed
    Member PacNW Supras/www.celicasupra.com
    Quote from Popular Science
    Despite the constant physical and--judging by the twitchy, panicked expression--mental punishment inflicted on him by Dr. Bunsen Honeydew窶冱 experiments, Beaker keeps coming back for more. Clearly the Jackass crew grew up ingesting a healthy dose of these Muppet Show regulars.
    Dec 2004
    Indianapolis
    140
    Yeah, I have looked throught the EM section and the EM portion of the Service Specification section and I don't see any of the numbers that I am looking for. It does give some specs on warpage, but that seems to be about it for the cylinder head and the block surfaces.
    1985 Toyota Supra
    Clifton NJ
    2,520
    84 mt 6mge with intake, exhaust, suspension, brake, and wheel mods
    85 mt 6mge stock
    Seattle, WA
    9,445
    See previous post from him. No help here, he already looked.
    Chris Eng
    Stone Age, FL
    4,871
    Sounds like you've figured out some of the "race engine" info. that's missing in the TSRM. :lol: Now all you/we need is the specs. for the stock valve timing and cam profiles. 8-)
    Dec 2004
    Indianapolis
    140
    Well, I wouldn't take any of the numbers I posted as exactly accurate. I am going to repeat the combustion chamber volume and piston dish/dome volume measurements so I can validate the first round of measurements. I am preparing the supra for scca ITS and there is a very detailed set of allowed engine modifications. The one I am working on at the moment is raising the comp. ratio by 0.5. I don't think it is going to take much to do that but I don't want to raise it more than the allowed amount and I also want to keep the valves from hitting the pistons. So if anyone else has any of the measurements it would validate my results.
    1985 Toyota Supra
    Dec 2004
    Indianapolis
    140
    If anyone is interested, I repeated the combustion chamber volume and piston dish/dome volume measurements.
    Combustion Chamber Volume = 52 cc
    Piston Dish/Dome Volume = -3cc
    These numbers are for a stock 5mge.
    1985 Toyota Supra
    Stone Age, FL
    4,871
    Quote Originally Posted by rwhite
    What spark plugs did you use when measuring the combustion chamber volume? The stock heat range ND/NGK's, or something different??
    Keep the discussion going boys...information coming out in this posts is just awesome. I'm gonna sticky this posts for now...good stuff.
