Results 1 to 8 of 8
    Apr 2005
    Merced, CA
    418
    1983 supra check engine light?
    to my knowledge there isnt one , but if there is why wouldnt it come on and how would i go about fixing it cause i need to get it smogged asap. if yoiu have a pic out of a manual or a book on the car that states there is no CE light that would work cause the guys over at teh smog places book says it should. any help would be appreciated.
  2. #2
    Jul 2003
    Naples, Fl
    16,222
    well, I just swapped my cluster from the 1983 85mph to a 1985 130mph speedo and I now have a check engine light. For whatever reason, it did not work in the original cluster. *shrug*
    1985 P-type 5 speed
    6MGE
  3. #3
    Feb 2004
    Sac area/Bay area
    319
    83 shouldent... unless its an 84 model year, (obd 1 was mandated in 1984) and any on board diagnostic equipment that was avalible beforehand was strictly at the manufactures graces, and fairly stupid at best... i guess toyota was feeling generous, i recall working on an 84 ltd 6 cylender, that the only 2 times the check engine light was made to come on is either when the motor is running excessivly hot (i use the term exessive loosly here) and when the engines oil pressure was low, any ecu related faults had to be painstakinly sought out with an analog volt meter, and otherwise went blissfully unnoticed by the driver...
    Angel=85 p type super white rip 5/07
    Memphis=84 p type with l type seats
    msd wires, coil, magnaflow high flow cat and muffler, drop in k&n with modified box and resonator.
    Vegas=85 p type black on black leather,
    7m turbo, disaster area.
    an old friend once told me... "i like pussy, and a supra will definatly get me more!"
  4. #4
    May 2005
    Florida
    35
    My 1983 Supra does have a check engine light, take a look.
  5. #5
    Jul 2003
    Naples, Fl
    16,222
    you need to take a duster to your dash
  6. #6
    Sep 2003
    Oklahoma
    3,582
    Quote Originally Posted by 85 rat rod
    83 shouldent...
    Yes it should.
    1983 was the first year of the Check Engine light.
  7. #7
    May 2005
    Florida
    35
    bah i dont need to dust im a man! and i work 45 hours a week...no time for cleaning.
  8. #8
    May 2003
    Mt Vernon, MO
    2,064
    On the 1983, the check engine light should come on when you turn the key to on without starting the engine. If your seatbelt light next to it and the other dash lights come on then and just not that one, it is probably a bad bulb.
    Jan. 1982 Blue 'P' type - DD, 6MGE intake/exhaust/17"SquareWheels, etc.
id=a6141150">
