ribid chimp turbo kit
Results 1 to 6 of 6
    Member
    Aug 2005
    Buford GA
    70
    Is any one running a rabid chimp turbo kit? How much boost/ power can you get out of a 5mge with this kit? thanks matt.
  3. #2
    CelicaSupra.com Member drftsupramk2's Avatar
    May 2004
    Don Cheadle fan club hq. Tacoma,wash
    1,170
    The power of 7777777777777oooooooooooooo twinkies. Boost and power depends on tuning, engine age\preparation for turbocharging, Air Fuel\Ratio. from what I've heard the mid 200s. But why don't you ask Aaron himself on his section here on the forums or pm him. He'll give you an honest answer. Also try the search man-Large Larry
    -Large Larry
    94 BMW 3 series (black) 84 P-Type (Stolen) (2 Tone Bob S. blue) one owner mint
    85mk2 6mge, Rabid Chimp 6mge, 62mm throttle body(Broken) , 7mge clutch Cover, Act Ceramic 4-PUCK, stainless steel braided clutch line, Rabid Chimp 2.5" cat-back exhaust .(sold)83mk2,mk3 (Rip now currently pop cans)
  4. #3
    CelicaSupra.com Member oldschool85's Avatar
    Apr 2003
    Denver, PA
    1,994
    mark made 271rwhp with that rabid chimp at like 11 psi or was it 13psi.
    charlie
    7m Powered Mk2 SOLD SOLD SOLD
    Hidden Content
    86 ptype-2jz coming near you Hidden Content
  6. #4
    Chango Loco rabidchimp.com's Avatar
    Washington State
    3,291
    Quote Originally Posted by oldschool85
    charlie
    Though he did do 271 rwhp, it wasn't "technically" with my kit. He did use a lot the same components, my IC piping kit, oil lines, turbo inlet and air filter setup, and cartech rising rate fuel pressure regulator. He was also running 295cc injectors, and a stock 7mgte down pipe, and turbo elbow. My kit has a 3" dp, which replaces the turbo elbow. You have two options with the turbo kit, one, which is the basic setup, uses a rising rate fuel pressure regulator. The other has an additional injector controller, with two extra injectors. Your car, if tuned properly, should do around 220 rwhp with either setup....to start with.
    -Aaron
    Hidden Content Hidden Content
    Hidden Content
    Lakewood, WA
    Providing parts and service to Mk2 Supra owners since 1999
    Send me a text message: 253-353-5140
    Last day of business will be 12-31-13
  7. #5
    CelicaSupra.com Member CRF_Rider's Avatar
    Portland, OR.
    794
    Yea, what he said.
    Mark
    88 T 5spd SR (SOLD)
    Hidden Content
    85P 5M-GTE (Now with another owner)
    Hidden Content
    It's "ORE-GUN" not "ORA-GONE"
  8. #6
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    12,790
    ...though that ~220rwhp figure is not the limit of his kit. There are always changes to be made for that next step in power. With a rising-rate regulated fuel-augmented system, fuel pressure is the only limit to your enrichment. Fuel pump upgrade will allow a higher total pressure, another option is slightly larger injectors 10-20%and adjust static pressure to meet stock flow and allowing a lower fuel:boost pressure ratio and thusly a higher "ceiling" of pressure and output, allowed boost, and resultant power.
    ...and all around the time where the headgasket pops because you ran a stock gasket at 9psi at stock compression with no boost-dependant timing retard.
    1 million variables and counting, but the chimp's kit is DEFINATELY a starting block!
    --BillyM
    White 85P - Blue/Silver 85P
    Hidden Content
    Hidden Content
