whats the biggest size engine i can put in my 85 celicasupra - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    CelicaSupra.com Member
    Nov 2004
    Davenport, IA
    391
    Quote Originally Posted by EnjoySupra
    yeah and i just put in a w12 audi engine in mine.. it fit peeeeerfectly
    that engine is pure garbage compared to the vector W12. I put a 16 cylinder radial from the spirit of st. louis in mine and I had some trouble with hood clearance.
  3. #12
    CelicaSupra.com Member Rich64N's Avatar
    Jul 2003
    Tacoma, WA
    3,001
    With enough money and technical knowledge, anything that will fit in the engine bay You are new, and this is an old topic ever since Reg Reimer did the first one in the early 90s, so I'll make a quick summary that is old news to most here, and I am not saying it is easy. The MK II came with a 2.8L NA 5MGE engine.
    The only relatively easy swap is the Toyota 6MGE (3.0L) engine at a bit over a grand for the engine (see http://www.rabidchimp.com for details).
    Next is putting in the MK III Supra (86.5-92) engine in the MK II, either the 7MGE or 7MGTE (turbo) (3.0L). If you are going this route, you might as well go for the turbo since the cost is little more considering how much you are spending. There is lots of info in the engine swap forum, but there have also been lots of partially completed projects sold becuase it was beyond the ability of the person trying to do the swap (ditto folks trying to put the 7MGTE into Toyota trucks - cheap source of parts for those that know). You need to be able to read the engine wiring schematics, and know how to rewire plugs to the ECU (engine computer) for one. I could probably figure it out having an engineering degree and experience, but if I were doing this I'd probably haul the car to one of the folks that has done this and pay the grand for the rewiring. You don't have your location in your profile so I don't know if that is viable for you (WA State, PA, and MD (yes, Hirsh ) are the 3 folks I know with experience in this).
    Next, the even more exotic Toyota engines, 1JZ and 2JZ. Based on the lack of details in the single line you posted, you probably don't have anywhere enough knowledge/experience to do this (I don't either), though I have no idea if you have enough money to pay someone else to attempt it.
    There are also possibilities in the Lexus engines. But VERY pricey.
    And finally, non-Toyota engines. It can be done so long as it fits into the engine bay, and you can get all the accessories to work. Probably a 6-month plus project unless you are a professional swapper. For one, the clutch or transmission probably won't mate up without a specially fab'ed adaptor plate.
    Hopefully, this isn't a troll first post. If it is, you should put in a Toyota 22R engine, which is Toyota's most dependable engine, though not its largest. Other than maybe the engine mounts, it would be easy. (if I saw a 22R in a Supra, I would first laugh, then look at it, it is a great engine)
    In any case, welcome, and look in the engine swaps section, where there are 3 forums on this general topic. [corrections welcome, I've only done a 5MGE to 5MGE swap, but have been around]
  4. #13
    CelicaSupra.com Member Deanfun's Avatar
    May 2003
    Fort McMurray, Alberta, Canada
    3,189
    We should quote Rich64N's post for every "lol what motor should i install" post.
    Dean L.
    1985 Toyota Supra - Hidden Content
    1987 Toyota Land Cruiser BJ73
    2007 Lexus LX470
  6. #14
    CelicaSupra.com Member mark5mgte's Avatar
    Nov 2005
    Medicine Hat, Alberta, Canada
    121
    ninja 600 in mine.. rev's like old hell!
    Don't try this at home... turbocharging a 5m without using parts from any other engine costs WAY TOO MUCH! Rods and pistons OUCH!! oh well.... at least the engine will last at 400+rwhp.
  7. #15
    Nov 2004
    Davenport, IA
    391
    Quote Originally Posted by Rich64N
    That is a great post and probably should be stickied for all the noobs to read when they first get in here. Now I am just waiting for the first guy to drop a 22r in.
