xJZ Swap FAQ - Page 15
Page 15 of 15 FirstFirst ... 5131415
Results 141 to 145 of 145
Thread: xJZ Swap FAQ
  1. #141
    CelicaSupra.com Member
    Sep 2003
    De Pere, WI
    1,947
    Which transmission is it in the car? How is the speedometer hooked up, if at all? Is the check engine light on, have they checked for trouble codes? Off the top of my head if you do not have a proper speed signal, you will have issues with an auto trans.
    When you say it wont rev up, is this while rolling in gear or in park/neutral? Factory ECU with stock tune, or any piggybacks?
    Someone send me a 2JZ harness that they need fixed, modded, or thinned down. I'm becoming bored very quickly.
  3. #142
    CelicaSupra.com Member ihateu3's Avatar
    Feb 2010
    ashland ohio
    1,401
    The NSS will produce a soft rev if not bypassed or wired in correctly.
    This message will self destruct
  4. #143
    Oct 2007
    Near Paris
    117
    Can someone confirm ? please thanks !
    It's for 2JZGE swap with original W58
    2JZGE > JZ Bellhousing to W58 > W58 5MGE original Clutch > W58 5MGE original Fork > Original W58
    And
    2JZGE > JZ Bellhousing to W58 > JZ NA MT Clutch > JZ NA MT original Fork > Original W58
    both are ok ?
    In a word... If you go with 2J NA MT clutck kit on original mk2 W58...you have to use the fork from JZ ?
    Finding mk2 W58 clutch kit is difficult instead of Clutch kit for NA JZA or SC300 and I would like to confirm what combination is ok for the original mk2 W58
    Thanks for help !
    It's difficult to find information sorry if already seen in previous post...
  6. #144
    CelicaSupra.com Member bevani's Avatar
    Apr 2008
    Canberra, Australia
    298
    im running all original fork throwout and slave for the factory w58. little bit of farting around but it can be done. biggest issue i had was the factory slave needed to be spaced between the bell housing and slave in order for it to press on the fork correctly. honestly the fork does need to be longer but ive had no issues with mine
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    JZA61: 1JZ, GT35....That is all
  7. #145
    Member
    Mar 2015
    Marysville, WA
    41
    i've seen fuel pump mentioned multiple times in different 2jz swap threads.. however, i haven't been able to find if the 5m fuel pump will work with a NA 2jzge. If it won't work, why not?
