Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Aug 2006
    milwaukee
    37
    Rack and Pinion boot leaking P.S.F.
    I just bought an 86 mkII from a used car dealership yesterday, everything looked fine. When I got home and turned into the driveway, I noticed a bunch of power steering fluid all over the ground, running up to the drivers side of my car. I looked under it and saw power steering fluid leaking out of the boot. It only seems to leak when I turn it all the way; is this going to be a long and hard fix? I lost the tip of my finger on my right hand, so I'm on workman's comp, but I need to get my car fixed ASAP so I can get to work when my finger heals up. I'd rather not be investigated for insurance fraud because I was caught working on my car.
  2. #2
    Aug 2005
    Australia
    333
    Couldn't tell you whats wrong with the rack (might be a seal), but its fairly easy to take out. Just undo the 4 bolts on the crossmember, unbolt the tie rod ends from the steering arms (knuckles), then loosen the bolt in the steering shaft and she comes out fairly easily. I'd say it needs a rebuild though. If you can take it out yourself and take it to a shop where they can rebuild it, you'll save yourself a bit of cash.
  3. #3
    Auburn, WA.
    5,757
    The high pressure hose could have failed or be leaking-the hoses bottommost point is righ above boot-If hose failed on under side, you wont see fault-This happened to me, and I almost had rack out before I noticed actual cause-otherwise, rack seals are blown
  4. #4
    L.A, CA
    7,087
    Adding a location in your profile might help get someone locate someone close to you and see if they are willing to help.
    85 Jet Black 5spd
    85 Jet Black 5spd
  5. #5
    brandon82mk2 Guest
    rack seal .my car is an 82 with an 84 rack and its starting to leak out of the boot also
  6. #6
    Aug 2006
    milwaukee
    37
    I got sick of trying to figure out what exactly could be leaking, so I bought an entire rack and pinion setup. Taking it off was one of the biggest pains in the ass, surprisingly, the line that screws right into the PS reservoir would not come off at the rack, and trying to take it off with a wrench caused the entire nut to strip I ended up buying tie rod ends and a replacement line for that, the rod ends were so rusted onto the rack that I just said screw it.
    At least I'll be able to steer again. My question now is, is a front end alignment easy to do by yourself or am I going to pretty much have to pay a mechanic to do it?
  7. #7
    May 2006
    Wmsbg, VA
    227
    Save yourself and pay. Unless you have access to an alignment rack. That would save you a bit of money.
    White 1981 - currently in torpor going through the resurrection...
    Quote Originally Posted by chassisb0t
    what does this switch do?
    Quote Originally Posted by Angkistrodon
    Opens the machine gun-ports. But you have to do the mod if you also want your fog-lights to come on.
  8. #8
    Aug 2006
    milwaukee
    37
    my mom took my car in for the front end alignment because she wanted to drive my car, and after it got home and i drove it, it had a nasty pull to the left while im on the highway, and a loud "clunk" noise when i turn right or hit a bump.
    it sounds like throwing a small stone at a two-by-four.
    my friend who is better than me at cars says that its either a busted tie-rod end, or the lower ball joint is fucked, but im wondering if it was the garage's fault. i mean, i just replaced the tie rod ends, and i put everything in right, and didn't mess around with them afterwards. the last person to touch anything with the rack and pinion setup was whoever worked on my car. i tried tightening the lugs but they wont tighten any further.
    any ideas as to what could be the cause of the mysterious clunk?
  9. #9
    Seattle, WA
    9,445
    Good grief!?!?!?!??????
    Who did the front end alignment??? These guys sound like morons!!!!
    Besides doing the alignment, they should have test driven it. If the car is now pulling, these "TOOLS" should have diagnosed & corrected the problem.. Or given you an estimate of what needs to be replaced.
    Take the car back to these dingbats... Or take it to another shop.
    And uhmmm.... NO........ Tightening lug nuts will not fix a wheel pulling problem.
    Here's another simple thing to check.... Tire/Air pressure.
    Chris Eng
    1981 MA47 Silver Metallic 5ME Automatic
    1985 MA67 Super Deep Red 5MGE 5-speed
    Member PacNW Supras/www.celicasupra.com
    Quote from Popular Science
    Despite the constant physical and--judging by the twitchy, panicked expression--mental punishment inflicted on him by Dr. Bunsen Honeydew窶冱 experiments, Beaker keeps coming back for more. Clearly the Jackass crew grew up ingesting a healthy dose of these Muppet Show regulars.
  10. #10
    Aug 2003
    Oshawa, Ontario
    3,860
    if you swear you installed the parts correctly and creased the new ends, I'd be taking it back to that shop and getting them to fix what's required....that doesn't sound right at all.
    Black 7M-GE 84 P-type Hardtop
id=a6141150">
