Up for sale are four 17" Akuza Sublime wheels with 245/45ZR17 Continental Contisport Extreme tires. I will also include the adaptors so that they fit properly. The wheels are +40mm offset and 4 x 114.3 bolt pattern. Tires have lots of tread left, should be rebalanced before install on your car. I can have this done for a small fee. The adaptors were custom made and are hubcentric to the car AND the wheel. The only thing you need is the longer wheel studs from a Toyota truck. These are NOT wheel spacers, which are dangerous. These adaptors allow the offset to match the stock loading on the hubs and bearings, meaning the centerline of the wheel is the same as stock. You may get slight rubbing in the turns on the front if you are lowered, as the tires are slightly larger than stock diameter. I went back to stock wheels and tires as I'm going for a more stock look. Shipping will be expensive, however I am in Las Vegas and if you are coming to SILV(as you should be) you can pick them up then. If you bring wheel studs, I'll help you install them and you can drive home on your new wheels. Here's what I paid.
Wheels $520.00
Tires $450.00
Adaptors $400.00
You can have all of it for $700.00
See them on my car here
http://www.cardomain.com/ride/475052
