diff removal/instalation writeup. - Page 6
Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
  1. #51
    CelicaSupra.com Member
    Apr 2008
    Sacramento
    160
    Quote Originally Posted by reevahz View Post
    on my 85 mkII says its F283 so that means its open right? lsd?
    F = 7.5" r&p
    28 = 4.3:1 ratio
    3 = LSD
    If it was:
    2 = non-lsd
    Andrew
  3. #52
    Feb 2004
    Austin, TX
    2,822
    The tip to put a jack on the frame rails and not the sub frame seems like a no brainer, but you'd be surprised... The bolts are m12x1.25 i believe, so if you are planning to chase the threads get one of those.
  4. #53
    Feb 2004
    Austin, TX
    2,822
    err double post instead of it editing for some reason. i used these tips to do 2 diff swaps in the last 7 days.
  6. #54
    May 2005
    N. Seattle.
    4,472
    YES!!! Very helpful,indeed. I'll be doing a swap soon.Just got a 4.10 LSD.This a sticky/FAQ,right?
    BTW,the stock oil pan drain plug(On my 5M) is the SAME size and threads as the diff drain and fill plugs. MUCH better hex to get a socket on and not strip out the heads of the plugs. It is a weird size. M18X 1.25...maybe.
    Make your own magnetic drain plug by Shoe-Gooing a small magnet on the inside or the outside of the plugs. Why not do both?Tranny,too.
    JB Weld would be more secure. I am the magnet man!
    When you drain out the gear oil,the magnet WILL be fuzzy with metal particles.
    Toyota puts magnets inside the tranny pan from the factory.So does G.M.
    You can find a large round magnet inside the magnatron of a microwave oven like the ones that G.M. uses.
    Computer hard drives have strong neodimium ones that are desirable.
    I'm draining my diff,now.
    I'll go with Mobil 1 and FORD friction modifier for the lubricant.
    Not Astroglide,as some one made a joke about.
    Besides, it's water based and won't mix with oil,anyway.
    I didn't get the Mobil 1. I got Lucas and it already has the friction modifier
    in the formula! Nice.
    I'll be 6 oz. short to fill the diff. DINO oil will be compatable.
    I'll walk up to MY NUH KEE and get a 1/2 pint.
    I'll paint it tomorrow. Probable blue. NO! White!
    I have 2 magnetic drain/fill plugs ready to go.
    Weird size gaskets: 18mm/11/16".
  7. #55
    Whistles racerxj220's Avatar
    Aug 2006
    Alabama
    577
    Nice. I hope you like the 4.10.
    William, were there pics on page one?
    Built 1JZ-GTE, PTE 6466, PGS Dog Box R-154, Pro-EFI 128, Nitrous, Flex Fuel, Headgames "R" cylinder head, SPF1 manifold, Hypertune, so much more...
    1983 Supra
    Jeffrey Rainwater
  8. #56
    Spring Hill, Fl.
    14,687
    Nope. Never did take pics while swapping the diff out. lol. Just separated the steps to make them easier to follow.
    william
    Hidden Content blue 85 beater
  9. #57
    May 2005
    N. Seattle.
    4,472
    I have some pix of my install.
    Make a platform to support the diff!
    Handy tools.
    http://i514.photobucket.com/albums/t...6.jpg~original
    http://i514.photobucket.com/albums/t...o.jpg~original
    http://i514.photobucket.com/albums/t...e.jpg~original
    http://i514.photobucket.com/albums/t...q.jpg~original
    http://i514.photobucket.com/albums/t...w.jpg~original
    The replacement 4.10 LSD is MUCH quieter.
    I did it SOLO and I am old.
    "Cheap-O " H.F. jack won't go up quite far enough.
    Magnet glued to the fill and drain plugs.
    I added Ford friction modifier to the Kendall gear oil B-4 the install.
    I had normal GL-5 oil before and around corners,it would load and unload the plates inside and the entire car would "Bam Bam".
    The original differential(Type L) was non LSD.
    This white one is it's 3rd one! Also,it's 3rd engine from an '85 car.
    Thanks to Dave Andrew,R.I.P. 2016.
    http://i514.photobucket.com/albums/t...l.jpg~original
    Also a shout out to ray85p for the lengthy,time consuming, engine install help + parts!
