Tire Shredder's 7MGE budget NA screamer build thread
Page 1 of 41 12311 ... LastLast
Results 1 to 10 of 409
    CelicaSupra.com Member Tire Shredder's Avatar
    Aug 2003
    London, Ontario
    3,955
    Hey guys, I thought it was time for me to post up one of these threads to help compile thoughts and get some suggestions and advice.
    The Idea
    The plan for this project came up around the previous fall when Alex (Kingsoup) and had a conversation regarding the merits of the 7mge motor at a Toronto supra club monthly meet. Later conversations involved Dean Anderson (Dean). We talked about how neglected the 7mge is in comparison the the 7mgte and even the 6mge engine swaps. We believed that the swap could be done cheaply and reliably enough to have some fun with your mk2, make it feel like it should have from the factory. We thought it would generally wake the whole chassis up, without having issues with transmissions and differentials breaking. Without the added cost of fabricating a new exhaust and intercooler piping, worrying about oil filter relocations, coolers and oil lines. The higher reliability of an N/A vs. turbo engine was there aswell (lets not argue about this, there simply is more things to go wrong with a turbo). When installed in a mk2, the 7m should propel the 3000lb mk2 into the 14s at the track and maybe keep up with a few mk3 turbos...cheaply. It all seems like a great package. We toyed with the idea of some basic fuel management and throwing some reground camshafts at it to get the most out of the more advanced, ported 24 valve head. I laid awake in bed dreaming of my very own budget NA screamer, and thinking of how I would get things done.
    As talks continued my plans evolved slightly...I wanted to do a little more than just install it. Thus far the plans are:
    -get a cheap 7mge
    -replace bearings if necessary, install new rings
    -clean head, hand lap valves, port work and port match myself
    -shave head and or block to increase compression to aprx. 10.5:1
    -new gaskets, oil pump (eBay)
    -later, install a maft-pro to tune fuel and timing, integrated with LC-1 (could be used later with a turbo build, so good investment)
    -after the bugs are worked out, install reground camshafts to use the engine to redline. 222duration at .50 though cam grinds have been selected (open to suggestions)
    -it has to look good when installed.
    this (I/we think) should allow for 200whp NA achievable.
    on initial start up, the Thorley headers and 2.5" Brullen will bolt up, and an intake fabricated.
    everything will be done "one the cheap" but not half-assed, I intend to get "quick(not fast), cheap and reliable" out of it, and have all three
    The story
    last spring, I was at Orville's house (local Toyota mechanic and club member). While he was fixing sawbladz's car, I was going to give a hand with his head replacement. In the Garage bay was an 87 N/A supra. The car ran nicely with no smoke or nasty noises, not so much as an engine miss. I was examining the wiring and vacuum lines when Orville asked if I wanted to buy the motor - everything, since it was undergoing a turbo drivetrain swap. We bartered down to $350 when I finally decided no, I didn't need to spend the money on it yet. Later in the month I went to the spring PA mk2 meet where Darcy had nearly all the 7mge parts from his car in his trunk and was handing them out for free. I got the head and many other misc. parts which I brought back to Canada. The head was in good shape and apparently rebuilt recently. I got a call from Orville wondering if I wanted the engine still, since he couldn't find a buyer for it. He had heard I got a head in good shape and since that was the only usable part (to him) he could have off the N/A, I traded him the head and cams for the complete 7MGE engine with harness and igniter. The engine is missing some accessories and EGR...which will be sourced later.
    Cliff notes:
    Free, well running 7MGE in my hands.
    I was able to get the engine back to my house in Oshawa (where I attend university) where I started disassembling and inspecting the parts.
    here's the engine when I got it
    Let The Teardown Begin!
    Time to start taking it apart, bagging, labeling and taking lots of pics!
    some manifolds off
    valve cover off
    Cams!
    Lobes look good, very little wear (not like my 5m!)
    The valve covers, I'm thinking polished with black lettering.
    Engine harness. nasty, but free
    taking apart the timing stuff
    Just bought this bit 10 minutes before the picture. The store owner and I joked about a lifetime warranty. trying to get a head bolt off and it snapped. I got a cut in my wrist when it let go. I did have a pipe on the end of it though haha. I returned it and got my money back. I bought a shorter, mastercraft version which did the trick.
    bought an engine stand! nice to not work on the ground. timing stuff is off too.
    The oil pan: will be replaced with a mk2 front sump unit.
    This is where all the pistons and stuff attach
    no trash on the screen. yaay!
    Oil pan, no trash. yaay!
    3L>2.8L
    taking the bearing caps off, no signs of any knocking. They all looked like this - very good! by now the butterflies worrying about spun bearings and scored pistons are gone, this is turning out to be fun!
    The block empty. pistons looked good and score-free aswell, just some discolouring from general blow-by, but other than that...should be a cheap machine shop bill!
    crank journals look perfect
    crank out of the block
    Everything is packaged and ready to head to the machine shop! within the next couple weeks I'll give them the head to clean and inspect it. Hopefully a full valve job is not required. Once cleaned, I'll start porting the head. You can look forward to pictures being thrown up here any time I do something on the motor.
    The engine gasket set is ordered and should arrive within the week, look forward to seeing some pictures of manifold port matching.
    any comments, good or bad are welcome here, I'd love to see some discussion going and gain some knowledge from more experienced members
    Steve
    Black 7M-GE 84 P-type Hardtop
    Hidden Content
  3. #2
    CelicaSupra.com Member Sawbladz's Avatar
    Nov 2005
    Oshawa
    624
    meh...just go turbo. LOL
    sorry...its my job to be a dick...now I will read it.
    Edit: looks good Steve, nice pics. I hadn't seen them yet. When you get stuff back from the machine shop and are about to start reassembly, come get me. Even if you don't need help. It would be nice to learn with you before I dive into mine (slated for later this year...funds allowing).
    1988 Supra. T4 58mm, 0.84 AR/FFIM/Cobra BBK/Coilovers/Poly Bushings/14 lbs/ 422rwhp; 2005 Ford Ranger EDGE.
    Hidden Content
  4. #3
    POTATO Tanya's Avatar
    Jul 2003
    Somewhere, FL
    16,966
    Looking good Steve, good luck with it
    Hidden Content
    Hidden Content
    Hidden Content
    1985 P-type 5 speed
    6MGE
    almost 9 years strong 4-20-08
  6. #4
    CelicaSupra.com Member jefe_not's Avatar
    Collierville, TN
    4,517
    Now that it's apart, and since it's going to the machine shop anyway, prep it for a metal head gasket... One more thing you won't have to worry about later!
    Jeff Sawyer
    I used to have a few Supras. I do miss them...
  7. #5
    Aug 2003
    London, Ontario
    3,955
    thanks guys. I'm not planning on installing a metal head gasket on this motor. simply put, it's overkill. when torqued properly even turbo cars with moderate amounts of boost survive with the stock head gasket. there is a local member that has been running 12psi for about 5 years (on original engine, not taken apart), torqued properly without issue.
    I will be using a stock type headgasket with copper spray and ARP head studs, torqued to 75 ft/lbs.
    Hidden Content
  8. #6
    CelicaSupra.com Member donkey2's Avatar
    Jan 2007
    Everywhere US
    1,078
    I second the metal head gasket it there is one thing I have learned on this forum it's what BHG means. Very nice and free you can't beat that. Not everyday you get a motor in that condition. Great pictures, I look forward to learning more 7m stuff. Good luck, the car gods smile upon you for you have sacrificed blood to them(again I'm sure).
    You need a hobby!
    Quote:
    Originally Posted by rsdeo
    I think it's Alex!
    Quote:
    Originally poseted by turbogoo1
    Nah I didnt see a grapefruit shooter...
  9. #7
    CelicaSupra.com Member Chrisfrom1986's Avatar
    Feb 2005
    Fresno, Ca
    6,499
    Keeping my eye on this.
  10. #8
    Steve;
    i can NOT wait to see this car running with the 7m in it. You've spent so much time reading and researching...this car is going to be a frick'n screamer...too bad you still won't be able to keep up with my cammed 5m .
  11. #9
    Aug 2003
    London, Ontario
    3,955
    grudge match?
    Hidden Content
  12. #10
    CelicaSupra.com Member Solo1Supra's Avatar
    Nesquehoning,PA
    4,102
    I'll be watching this thread as well. It's what I should have done instead of dumping money into 2 6M's.
    Joe B.
    '85 P-Type
    '89 MK III
