Page 1 of 41 12311 ... LastLast
Results 1 to 10 of 402
    Oct 2005
    Norwalk, IA
    3,836
    Lee_MA61's 2JZ-GTE build thread
    So I've finally gotten close enough in parts i thought i would start a build thread. Not only will this help keep you guys informed but it will help keep me on track. In the end we will reach a major payoff that everyone will enjoy.
    So stick around check out the pictures and stories. I'll be updating my To do list every so often along with pictures. Maybe someone might be able to help me with a part sourcing along the way.
    To do list: Completed
    1. Rebuild Engine
    2. Engine / Transmission mounted
    3. Wiring
    4. Fuel System
    5. Turbo Oil lines/ Oil cooler
    6. Inter-cooler piping
    7. Exhaust
    8. Tuning
    To buy list: Purchased Items
    • 2JZ-GTE
    • Front-Sump oil pan
    • Eagle H-Beam connecting rods
    • JE forged pistons (Standard 8.5:1 .20 over)
    • Cometic 2.0mm MHG
    • PT74GTSHP
    • RPS Long tube Turbo Manifold
    • HKS racing waste gate
    • Aftercooler A.K.A "Intercooler"
    • TiAL 50mm Blow Off Valve
    • Titan motor-sports Fuel Rail duel feed 8an/6an return
    • Titan motor-sports 1600cc (151lb domestics) injectors
    • Aeromotive A1000 regulator duel 10an in/6an out
    • Aeromotive A1000 w/ pre and after filters
    • Clevitte bearings set
    • Main bolts
    • Oil squirters
    • Oil Pump
    • Water pump rear housing/Meizure electric water pump
    • Complete timing belt setup
    • Complete serpentine belt setup/tensioner
    • Alternator
    • PS pump/Reservoir
    • Haltech E6A EMS
    • MSD DIS-4
    • R154
    • 1JZ bell-housing
    • 1JZ clutch and flywheel setup
    • Drive-shaft
    • Engine mounts MrTechNic
    • Mk.II Auto tranny mount
    Engine Build:
    Teaser Install:
    Pictures of the build of the years so you don't have to scroll through all the pages..
    Fuel pump/kill switch/Sump'd tank:
    Intercooler mounting/Wire tuck:
    Fuel System
    Final engine mount:
    picture consolidation.......
    http://youtu.be/pNU6mIMYEVg
    Thanks,
    Random House Racing
    -1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm) JZA61 History thread
    Charlotte, NC
    1,141
    Let me know what engine mounts you end up using. I'm also looking for a set.
    RIP Les Grover
    * WANTED mint '84 P-type, any color, no mods, manual trans *
    Mar 2006
    st cloud mn
    876
    You do know your going to have to take a trip to Mn with that thing when its done....
    Nice job so far man thats one clean car to begin with can/t expect anything less for the swap too.
    -Sean
    1983 p type (the mad max supra) 5mgte-sold
    1996 honda prelude Daily Driver
    1987 supra turbo7MGTE full port job comp springs HK$ MHG, Custom FFIM, Q45Tb 3" charge piping, GT4088, AEM EMS, A1000, RC720cc injectors, rebuilt bottom end,50mm wastegate, N2O
    thanks Tanya for the sig!
    BillyM's Shift-Gasm install on R154
    http://forums.celicasupra.com/showthread.php?t=35972
    Quote Originally Posted by My little bro
    Your car is so slow I can fry an egg on its turbo!
    Oct 2005
    Norwalk, IA
    3,836
    Quote Originally Posted by funky_monkey58 View Post
    -Sean
    I'll definitly have to check it's "road worthyness" when it's done.
    I'll have more posted up today.. Just working sucks.. ha ha
    Random House Racing
    Oct 2005
    Norwalk, IA
    3,836
    Updated Pictures, Still more to come. Please let me know what you guys think of the links, Should I keep them or go with fixed pictures in the thread?
    Thanks for looking,
    Random House Racing
    Mar 2006
    st cloud mn
    876
    I spy a white mkiii :P
    I like your pistons better than ours...
    http://i41.photobucket.com/albums/e2...achineshop.jpg
    Oct 2005
    Norwalk, IA
    3,836
    Yup Mk.III FTL lol
    I'm sure my pistons will look like that too after a few miles of use. ha ha
    Random House Racing
    Oct 2004
    Ft. Lauderdale
    6,255
    I love how smooth the 2J valve covers and spark plug cover are compared to the 1J
    '85 P-Type 1J "The Torqueless Wonder"
    557whp/449wtq@25psi on 93 octane
    Precision 6266SP CEA
    Sponsored By
    Toledo, Ohio
    118
    I see you rebuilt the 2j did you have any problems getting the harmonic balancer off to take the timing components off. because I have tried damn near everything to get the bolt out. I've tried light heat from a butane torch, impact gun, 3 foot breaker bar and prybar on the flywheel to hold the crank still. but my compressor is only a 20 gallon 1.5 horsepower. but I even turned the presure up to 150 psi and my husky impact still didn't take it off and my husky impact is rated at 600 ft lbs in reverse. IDK any thoughts on my issue?
    Supra's fu**in rule.
    Oct 2005
    Norwalk, IA
    3,836
    I didn't have that much trouble, wow.
    What I did was, removed oil pan (upper and lower) placed a bar with a towel wrapped around it between the crankshaft and block (wedge affect). Then I used a breaker bar and "cheater bar" on that. It broke free first try, BTW this was on an engine stand.
    ____
    Side note, we took apart my friends 7m-gte today and the harmonic balancer bolt was finger tight!! Not so good..
    Random House Racing
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Wyvern89
