Current Exterior body trim and rubber availability
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    2JZ in the hole
    ra24man's Avatar
    Jul 2004
    Vancouver, WA, USA
    3,656
    Hey everyone, just a little update as to what's currently still available for the MkII's...this is subject to change, so make sure to check back from time to time. Here it goes....
    54125-14011 $47.10 R HL ‘WHISKER’ (trim between the bumper cover and the headlight)
    54126-14011 $47.10 L HL ‘WHISKER’
    53852-14020 $10.61 Flare Filler (5)*
    *These pieces, in the noted quantities, should do all the flares on a P-type except the little one on the right rear flare that is closest to the fuel filler
    63251-14020 $45.93 Sunroof Weather Strip
    62381-14090 $53.40 R Window Weatherstrip (seals the top of the window)
    62382-14090 $53.40 L Window Weatherstrip
    75531-14120 $46.56 Windshield Molding, Top
    75533-14160 $46.49 RH Windshield Molding
    75534-14130 $46.49 LH Windshield Molding
    75710-14160 $109.40 RH Door Belt Molding
    75720-14160 $109.40 LH Door Belt Molding
    75671-14080 $72.50 RH QTR Belt Molding
    75672-14080 $72.50 LH QTR Belt Molding
    75581-14100 $10.84 (X2) Back Door Corner Moldings, Upper (hatch 82-84)**
    75583-14070 $10.84 (X2) Back Door Corner Moldings, Lower (hatch 82-84)**
    **these pieces are not stocked in the US, special order out of Japan takes 2-3 weeks to get usually
    76873-14020 $8.99 (x2) Back Door Spoiler (85-86 cars, the ones down the sides of the hatch, between the spoiler and the hatch)
    69685-12010 $1.05 Rear lock cylinder gasket (hatch)
    A list of the unavailable pieces follows:
    Rear Head Light Protectors
    Support extensions (the plastic things behind the headlight. You know…have to take the left one out to get the battery out)
    Head Light Doors (trim around the head light when they are popped up)
    Front and Rear Hood Weatherstrips (at the radiator support and the cowl)
    85 Back Door Glass Weatherstrip
    Gutter Moldings (A pillar- QTR Garnish, none of those gutter moldings are available)
    QTR Garnish (the triangle shaped piece at the back of the QTR windows)
    B Pillar Garnish (the gloss black one with the emblem on it)
    License Plate garnish (holds the license plate and lights)
    Inner Protectors for the 85 Supra rear spoiler (the one’s that run down the glass between the glass and the hatch spoiler)
    82-84 Rear Hatch Visor rubber pads/seals
    Rear Hatch Stoppers (the rectangle shaped rubber blocks that keep the rear hatch from rattling)
    Back Door Window Moldings, ALL (hatch 82-84)
    Misc. Flare Fillers
    Back Door Glass Weatherstrip (Hatch) 82-84
    Left Door Weather Strip (seals door to body)
    Right Door Weather Strip
    Windshield Cowl Cover
    Back Door Weatherstrip (Hatch)
    Whew! I may have missed a few so, if I did, feel free to slap me around and let me know, and I’ll add it to the list. I didn't add the body side moldings to the list since they have been well documented in another thread. Thanks!
    Mark
  3. #2
    CelicaSupra.com Member denvermk2's Avatar
    May 2007
    Colorado
    1,575
    I wish you had pictures or diagram. I am confused which is which.
    Hidden Content
    Robin
    1985 Silver Supra P |2002 Audi A6 Avant | 2008 Subaru Outback XT
    Hidden Content
  4. #3
    CelicaSupra.com Member spud3861's Avatar
    Charlotte, NC
    1,819
    Awesome thread idea, although I'm worried that there will be a sudden rush on these aprts, most of which I still need!
  6. #4
    CelicaSupra.com Member 82phoenix's Avatar
    Jul 2003
    Quesnel, BC, Canada
    987
    Thanks for the list Mark. I will need most of these pieces, I'm sad the gutter mouldings aren't available anymore. Will have to try to refinish those to match the new.
    Will Parker
    Hidden Content
    82 MA61 (project)
    85 RA64 (project)
    87 MA70 (R.I.P)
  7. #5
    CelicaSupra.com Member Malibyte's Avatar
    Native Canuck in SoCal, USA
    2,520
    Mark:
    Off of the top of my head, this is what I'm pretty sure I need:
    One of the flare filler pieces (the lowest portion on the right front) for my '85, possibly the upper windshield molding and right rear quarter-window molding for my '84, and some of those damn clips that hold the windshield side-trim pieces down - I can't get those damn upper corners to sit down like they should.
    I will go over both cars completely this weekend, then send you the complete list of what I need.
    Thanks
    Bob
    '84P 5-speed - 2JZ-GTE, PT 6265 turbo, R154, 3.58 - 465 rwhp @17 psi
    '85P 5-speed - 5M-GE - BPUs - otherwise unmolested
    Hidden Content
  8. #6
    Mar 2005
    Santa Cruz, Ca. 95061
    3,886
    pics
    Quote Originally Posted by denvermk2 View Post
    Actually, I thought he did an excellent job of describing the various parts, their location and application. Read it, look at your car....you'll figure it out.
  9. #7
    2JZ in the hole
    ra24man's Avatar
    Jul 2004
    Vancouver, WA, USA
    3,656
    Quote Originally Posted by Malibyte View Post
    Mark:
    Thanks
    Bob
    Hey Bob...most glass guys ditch the clips and add a little extra urethane sealer under the moldings to glue them on. The windshield moldings listed are for the 85-86 cars. There's a couple or reasons behind that madness...first of all the newer side moldings come with the corners already attached to them...second and most important of all...the earlier moldings are discontinued...including the corner pieces.
    Mark
  10. #8
    2,520
    Quote Originally Posted by ra24man View Post
    Mark:
    Yeah, I've thought about doing that but figured that I'd like to avoid it if I could use the clips with good results (in case I ever had to replace the windshield, I wouldn't need to ruin the moldings to do it). If anyone can give me a clue as to the best way to do that, it'd be appreciated.
    I already have the '85-86 side windshield moldings on the '84, so adding the top piece would just complete the set.
    Bob
    Hidden Content
  11. #9
    2JZ in the hole
    ra24man's Avatar
    Jul 2004
    Vancouver, WA, USA
    3,656
    Understood...pop me an email with your list when you're ready...and I'll get on it! Thanks!
    Mark
  12. #10
    CelicaSupra.com Member SkoonMA67's Avatar
    Apr 2003
    Saskatoon, Canada
    393
    wow... glad I got my stuff when I did hehe. Too bad about the gutter moldings though Mine are in rough shape now compared to the rest of the car!
    (just wait till you see my calender pics
    Also Mark, you forgot to list the 82-84 spoiler-to-hatch rubber pieces as being unavailable. AND, you forgot the hatch lock cylinder grommet
    Thanks again!
    "Technology is the only substitute for cubic inches"
    2006 Nissan Xtrail LE - "Exy" 192000km
    1983 MA67 - "Jessica" 210000km
    Your Friendly neighborhood BMW Master technician
