increase rev limit on stock ecu
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
    Spring Hill, Fl.
    14,642
    was bored at work and brainstorming some things id like to try for a n/a 6m that i might build just for who ha's for my 86, and remembered this mod.
    http://www.supramania.com/forums/sho...ht=ecu+crystal
    this theoreticlly should work on our ecu's no problem as they are very similar to ehe 4age ecu's the mod origonated from.
    the reason im thinking of doing this myself is i am thinkin of making a home made 6m, with the domed 9.2:1 5m pistons, 7m block and 7mgte rods, my p&p 5m head, tri-mil header after i mod it for a 3in collector, 3in exhaust, the gude cams which make power to 7600rpm according to the specs and im going to mod an intake for a larger tb and run 210cc/min injectors etc.. im thinking i can get over 200rwhp this way if the rev limit can be increased to 8k or so. of coarse i still plan to one day do the 6m wit hthe forged rods and high compresion forged pistons and the webers i have etc.. and aim for 250+rwhp. but this will be just for something more fun in the daily driver.
    william
    Hidden Content blue 85 beater
  3. #2
    CelicaSupra.com Member Dangerous Ken's Avatar
    Feb 2004
    Colorado
    3,937
    Quote Originally Posted by williamb82 View Post
    There's a big problem in changing how the ECU keeps time.
    Ken
  4. #3
    Spring Hill, Fl.
    14,642
    not really. it works fien on other cars. and it changes it across the board so all the maps are stretched the same. if you dont want to do it thats fine. i personally want to try it, and beleive itll work great. main problem people have had with aftermarket cams on stock ecu is the rev limit cutting in before peak power is realized, this would solve that.
    william
  6. #4
    CelicaSupra.com Member KurtW85's Avatar
    Mar 2005
    Tucson, Az
    2,539
    WHAT ARe YOU TALKING ABOUT!!! IT CANT Be DONe!!! ITS PROBLeMATIC!!! YOU ARe GUNNA BLOW YOUR ISH UPPPPPP!!!!??!?!?!?!&#WY%*Y@)*
    Regards
    '95 Corolla 367k and going(DD)
    '80 2dr Corolla 6m s366+W58+G series project; after 140mph 10'sHidden Content
  7. #5
    Spring Hill, Fl.
    14,642
    maybe if it was turbo, im talkin n/a, i have never seen an n/a car have an issue with this mod. and if i blow it up so what.wont be the first time ive blown somethin up and prolly not the last either.
    william
  8. #6
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    12,780
    Fancy idea... I'd like to see it in operation.
    --billyM
    White 85P - Blue/Silver 85P
    Hidden Content
    Hidden Content
  9. #7
    CelicaSupra.com Member sarinas_dragons's Avatar
    Jul 2003
    Parkland, WA
    3,121
    I have seen it. I've ridden in a car with it. I can't get in touch with the originator of this idea. I posted about it a long time ago and I was a noob and Junkie lit a campfire in my anooos. Maybe it wasn't Junkie, but just another fucker that built ass-fires the same way...with his fiery tongue.
    The car is still around, I saw it last year, at least. Remember? I said "......265 hp turbo-hachi shifting at 9 grrrrrrrrrrrrrrr aaaaaaaand!"
    Kenny
  10. #8
    Jul 2003
    Parkland, WA
    3,121
    If I sent you an ecu with the rev limit you wanted would you test it?
    Kenny
  11. #9
    Spring Hill, Fl.
    14,642
    yup. has to be an auto ecu at the moment. dont plan to swap the 86 to 5 speed till i get the 6m built i was talkin about, and then id only leave it that way for dyno time i think. i want 8k limit. though if you have a 87-88 7mgte ecu modded for 8k ill test that on the screwed up motor thats in the 84 right now since itll be replaced soon anyway. lol.
    william
  12. #10
    Jul 2003
    Parkland, WA
    3,121
    No I meant a test standalone.
    Kenny
