Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 174
    Greenville, SC
    11,678
    BillyM Shift Bushing Install (The "Shift-GASM")
    ...I know I know, been dragging my feet on this one.
    Tools needed:
    Flat-head screwdriver.
    Phillips-head screwdriver.
    Needle-nose pliers.
    RTV and or Epoxy.
    Carb-cleaner or alcohol. (beer doesn't count, vodka does though)
    Patience (know you're saving yourself a tranny pull and reinstall)
    Step one, pull all your interior stuff.
    (Curse twice for the engineer who decided to put the shifter under the console, radio surround, and temp controls. Asshole could have just put it under the console only.)
    ---A: Console has two screws in front, two in back, and two in the little compartment bottom, just move it back an inch or so, no need to unplug and remove.
    ---B: Pull the temp control knobs off (tug straight back, wrap with a shop towel and pull with pliers if needed) and three screws in it's face let it free.
    ---C: Pull your ashtray and you'll have six screws in the radio surround, it comes back and you unplug one connector. D: Two screws on the sides of the big plastic piece and it'll come free, up and over once the shiftknob's off (shift to third for easiest removal).
    ---D: Pull up the little rubber flappy at all four corners and pull the screws out, same for the four in the shifter itself, make sure you're back in neutral and pull the whole bastard outa' there. TADA! Look down in there and here's a better shot of what you're working with.
    http://www.celicasupra.com/gallery/data/2/IMG_0452.JPG
    Step two, removing the bullshit.
    --A: In the picture above, you see what this sucker's made of. Ring of metal, ring of rubber, ring of metal (MIGHT have remenants of a plastic ring too, but probably not). The plastic ring may be sitting down in the middle of it, or partially attached, pull it out if so. He's the fucker responsible for your sloppy shifter, throw it on the floor and spit on it.
    --B: One ring of metal (preferrably the inner one), has got to go. Looks bad, easy to do. Using a Flat-head screwdriver, pry out the metal ring a bit. Once you've got enough bite, use your needle-nose pliers and apply inward pressure while you work the metal ring away from the rubber wall a bit at a time until it comes free. Throw it on the floor and spit on it. Look here for an image of it...
    http://www.celicasupra.com/gallery/data/2/IMG_0453.JPG
    --C: Now comes the fun part, pulling that rubber bastard out of there. ...you do it the same way as the metal ring, but it takes more tact. Working the flathead up and down going around a little at a time, while applying pressure with the needle-nose pliers works best. You'll need to check down in there and make sure you got all the chunks and hunks out and you're set! Look here for an image of it...
    http://www.celicasupra.com/gallery/data/2/IMG_0456.JPG
    Out you bastards!
    http://www.celicasupra.com/gallery/data/2/IMG_0461.JPG
    Step three, installing the bronze bushing.
    ---A: Before you get all adhesive-happy, test fit that sucker a few times. Get your method down pat. You may or may not be able to drop it straight in between the pins depending on wear, lean it forwards and catch one of the pins at one of the notches. Do it a few times without hitting the sides of the aluminum piece. Now clean those suckers up REAL good with carb clean or alcohol on a rag. See image below for pic of it installed.
    http://www.celicasupra.com/gallery/data/2/IMG_0468.JPG
    ---B: Now, I used a good dose of epoxy around the barrel down in the tranny, and a goob line of RTV around the top lip, I then mirrored this on the bushing itself. ...being extra careful, I dropped it in, and smoothed the rtv around the edges, I then put some weight on the top of the bushing so that it set flush. Beer time! *does a dance*
    ---C: Put the little button bushing on your shifter and the Marlin Crawler upper bushing in the top section (set it in vertically and match the notches to the pegs, and rotate flat in there. Mmmmm success. I'd give it 24hrs to dry and solidify, give it a good check over and reinstall everything.
    Enjoy,
    --billyM
    Blue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
  2. #2
    Apr 2005
    Merced, CA
    418
    nice write up, when are you planning on selling more of those kits?
    1983 Toyota Supra 6mge - sold
    2008 Hyosung GT250R
  3. #3
    Greenville, SC
    11,678
    Thank you. I try to be thorough.
    Check the groupbuy section tonight.
    --billyM
  4. #4
    Apr 2005
    Merced, CA
    418
    ok cool, it might not be this month but ill more then likely buy one if they are still being sold next month.
    2008 Hyosung GT250R
  5. #5
    Oct 2005
    Norwalk, IA
    3,837
    Wish you could make something like this for the R154 I don't like the feel of the tranny when you are shifting it. Kinda wished it shifted more like a W58
    Awesome write up!
    Random House Racing
    -1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm) JZA61 History thread
  6. #6
    Greenville, SC
    11,678
    I'm still waiting to hear from someone with a r154 as to whether or not it fits. Lots of detailed pictures and measurements of the r154 would help too...
    --billyM
  7. #7
    Oct 2005
    Norwalk, IA
    3,837
    I could get those for you if you don't have somebody doing it already.
    Just say the word
    Random House Racing
  8. #8
    Greenville, SC
    11,678
    Werd.
    I need knuckle measurements, we want a 24mm inner diameter on the outer metal ring. I also need a inner diameter measurement on the shifter bore. Take a number of pictures (the little flower macro button is your friend) and get them to me too. If it'll drop down and fit tight, the whole kit ought to fit.
    On another note, I just installed this setup in a trans in my daily celica, and that makes two of my three drivers that have it. I won't ever use anything else. It can NOT be beat.
    --billyM
  9. #9
    Oct 2005
    Norwalk, IA
    3,837
    Alright I'll get working on that later today. Hopefully we'll have some good numbers to report.
    Random House Racing
  10. #10
    Jul 2003
    Fontana Cali.
    8,105
id=a6141150">
