Results 1 to 10 of 13
Thread: ECM Recalibration Kit
02-20-2008, 05:27 PM #1
hey guys i found this and didn't know if anyone had tried it or checked in to it.
http://www.autopartswarehouse.com/se...294966713+9349
but i found it interesting and thot y'all might.302 powerd supra!!
02-20-2008, 06:11 PM #2
I think its been pretty well documented in the past most of these ECU chips for Toyotas are nothing more than an expensive decal. For the most part only the Techtom parts are real (& very expensive) hack into the stock ECU and use a daughtercard.
02-20-2008, 07:01 PM #3
It is probably just one of those change of resistance on the water temp sensor deals... Higher idle what?! Someone who has a bit of money to burn should check it out though. Looks like this one is only for non-tems, non-vacuum advance ecus.
86 Black MA67: 87 7M, 300hp, no shit! 84 Brown MX63: It's a Dork, not Donk!
Check out some 7M Supra Videos!
Links: My 7M-GTE swap guide Electrical FAQ 85 MA61 TEWD 86 MA61 TSRM 87 MA71 TSRM 90 MA71 TSRM
02-20-2008, 10:21 PM #4
02-21-2008, 12:49 AM #5
02-21-2008, 06:54 PM #6
If I had a spare ECU i just might give it a go to find out before someone who can't afford to gets screwed that is if it is BS, or if it is real then let people know that it works.
You need a hobby!
Quote:
Originally Posted by rsdeo
I think it's Alex!
Quote:
Originally poseted by turbogoo1
Nah I didnt see a grapefruit shooter...
02-21-2008, 09:15 PM #7
- Mar 2003
- PacNW
- 9,837
Look at Kenny's list ---- Nothing remotely close to our ECU. I'd venture a guess, the Supra Turbo, if it is a MKIII, is 89+.
I got to see the $$$ sticker once. The car was dynoed before the ECU was sent out, dynoed when it came back === 0 HP difference. Pretty expensive sticker ...84 P-type, 7mgte, too many other mods to list, 20k miles on the chassis. 83 L-type, 7mgte/A340 swap, again, to much to list. 85 P-type, basicaly stock, DD.
02-23-2008, 01:00 PM #8Random House Racing
-1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm) JZA61 History thread
02-25-2008, 07:19 PM #9
has anyone checked into a MS setup? just thot i would ask cus i can get a complete setup to replace my ecm in the firebird for just over $600.
302 powerd supra!!
02-25-2008, 07:26 PM #10
- Mar 2003
- PacNW
- 9,837
^^^ignore list^^^
