Results 21 to 30 of 141
01-20-2009, 08:13 PM #21
I personally know someone who DOES NOT like there Cobras at ALL. Too hard and suck in the rain IIRC...
(on an 84)86 Black MA67: 87 7M, 300hp, no shit! 84 Brown MX63: It's a Dork, not Donk!
01-20-2009, 08:18 PM #22-Chris
1983 Celipra GTS:
02-25-2009, 02:29 AM #23
Junior Member
- Join Date
- Feb 2009
- Location
- Wisconsin
- Posts
- 6
Thanks so much for this thread. I was having the hardest time finding tires for my 84, an this was the only place i was able to get real help. Thanks a lot for this thread.
02-25-2009, 07:25 AM #24
Member
- Join Date
- May 2008
- Location
- GA
- Posts
- 90
03-26-2009, 03:02 PM #25
Junior Member
- Join Date
- Nov 2008
- Location
- Guayaquil, Ecuador
- Posts
- 3
Somebody know what happend if use an 15 X 7 wheel, what tire is the most recomendable.
Regards,
Carlos Mario
03-26-2009, 03:14 PM #26
03-26-2009, 03:16 PM #27
03-26-2009, 10:42 PM #28
CelicaSupra.com Member
- Join Date
- May 2003
- Location
- Mt Vernon, MO
- Posts
- 2,063
Just to clarify, 'H' does not fit where you would think logically (S, T, and U are lower). I think it used to stop at 'T' for domestics, but some foreign cars had better performing tires that they labeled 'H' for 'High Performance'. Then along came even higher ratings with the 'V' -'Z'.
'S' is rated to 112 mph and has relatively soft sidewalls,
'T' to 118 mph and slightly stiffer sidewall than 'S',
'U' to 124 mph,
'H' to 130 mph with firm sidewall,
'V' to 149 mph,
'W' to 168 mph,
'Y' to 186 mph,
and 'Z' is anything above 186 mph.
Our cars came from the factory with 'H' rated tires and using a lesser rating is not recommended.Jan. 1982 Blue 'P' type - DD, 6MGE intake/exhaust/17"SquareWheels, etc.
04-08-2009, 07:00 PM #29
- Join Date
- Nov 2008
- Location
- California
- Posts
- 272
Great post, thanks for taking the time to compile all this info.
Seems the BFGs are the easiest and most common tire in 225/60/R14
What is everyone's opinion on those tires? Decent or what? How do they handle in the rain/ice/snow? I see they are only rated to 112 MPH, thoughts, comments?
06-29-2009, 09:54 PM #30
Junior Member
- Join Date
- Jun 2009
- Location
- Alberta Canada
- Posts
- 9
