Cressida Wagon 6M - 5 Speed - LSD (Build) - Page 3
Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 164
  1. #21
    CelicaSupra.com Member
    Jul 2005
    Florence, AL
    173
    Push down belt release lever.
    It flashes and dings when you pull up the seat belt release lever next to the ebrake
    Quote Originally Posted by scorpmatt View Post
    what does the big button say in that pic? Push Down something Release Lever
    David W
    06 V6 Legend LimeMustang
  3. #22
    CelicaSupra.com Member sowsley's Avatar
    Jun 2007
    San Francisco
    2,337
    I'm a big fan of silver engine blocks, but other than that, nice work!
    Bad decisions make the BEST stories.
    1982 Supra P-type
    1982 Specific TSRM's
    Wiring Diagrams Hidden Content
    Emissions Repair Manual Hidden Content
    Air Intake System Hidden Content
  4. #23
    CelicaSupra.com Member droptopsupra's Avatar
    Apr 2006
    Chicago
    853
    Yep just like intelwalk said...
    The 85-88 Cressida have automatic sholder belts. There are two levers next to the e-brake handle that are there for safety.
    Quote Originally Posted by sowsley View Post
    Thanks! I was undecided about the color. I was going to go with something more universal, but my friend at the parts store talked me into blue.
    Hidden Content
    _________________________________________________
    85 Celica Convertible / Supra Front Clip Hybrid (Still Under the Knife)
    87 Cressida Wagon (6MGTE Hybrid being built, W58, MKI Supra 3.90 with Torsen T2) 6M Now - GTE on hold
  5. #24
    CelicaSupra.com Member Shift's Avatar
    Aug 2006
    Marysville WA
    427
    what ever happened to the convertable supra?
  6. #25
    Apr 2006
    Chicago
    853
    My DD and the wagon (mostly the DD) have been keeping me busy.
    I hope to get the convertible in the garage by the fall and start sorting through the wiring for the front lights and the dash. The body work is mostly done and it sits in primer. The 7mgte is at my friends house. Too many projects!
    Hidden Content
  7. #26
    Apr 2004
    Memphis Burbs
    1,751
    Quote Originally Posted by droptopsupra View Post
    Wow....and my brother adds something productive.... I didn't know you still watch this forum....
    More psi please!
    82 P-Type Red + Black Panda - SOLD
    86 P-Type Built Parts car Koni Sways - In a Tree - Tornado Victim
    85 L-Type Stock 15s - Destroyed by Debris - Tornado Victim
    85 P-Type ROH 17s, 6M(Valves, cams, etx), Mustang Dyno 154 hp/ 161 ft tq -SOLD
  8. #27
    Apr 2006
    Chicago
    853
    Quote Originally Posted by walkerhiboost View Post
    What's up Brian. You still out in the NW? As you can see... I've pretty busy with Cressida stuff.
    Hidden Content
  9. #28
    CelicaSupra.com Member xiong80s's Avatar
    Nov 2006
    California
    344
    Hey, so what driveshaft are you using? The stock one from the factory 5spd? Does it bolt up perfect? LMK
    Ol' Skool Toyz/1987 Cressida
    Hidden Content
    4Sale - 6M Pulleys - 5MGE Rebuild Head
  10. #29
    Apr 2006
    Chicago
    853
    Quote Originally Posted by xiong80s View Post
    I have a factory 5 speed drive shaft (front section). However, the wagons came stock with a one piece drive shaft. When I get to that point, I will have a custom driveshaft made... That is if I have any money.
    If not, I will use the stock one. It may need to be modified a bit.
    Hidden Content
  11. #30
    Apr 2006
    Chicago
    853
    Uh Oh!
    I spoke to the machine shop about cleaning up the rust dust from all of the machined surfaces again. We talked through getting the rust dust off with scotch brite light duty pads and then protecting the surfaces with oil. The type of oil would vary depending on how long it would be before I assemble the block. He said that WD-40 would be fine. He advised me to make sure that I got all of the soap off of the block with water, blow all of the water away with air, spray the machined surfaces with WD-40, and finally blow the block with air again. The WD-40 is not only to protect the block but to get rid of the water as well. I learned that WD stands for "Water Displacement".
    Great, so I got that done. Everything looked good but not as shiny as when I first got the block due to the layer of oil on the machined surfaces.
    I decided to pick up some plastigage and install the crank. This is the "Uh Oh" part. The bearings that I have are .25 undersized bearings. I installed the bearings, laid plastigage across the cranked and torqued the caps down to 75 ft/lbs. The clearances were much less than .025 mm which was the smallest clearance measurable with the green plastigage. The plastigage markings were as wide as the .025 and .038 measurements combined. I thought that was odd. I cleaned up the plastigage off of the crank and the bearings. I noticed that the plastigage left an indentation in the bearings. I thought that was odd too. I torqued the caps down again, to see how the crank was rotating. It was seized. I then removed the caps and the cranks still wouldn't turn. The crank eventually popped free. I hand tighten the caps and the crank turned with some resistance. So, there was practically no oil clearance.
    Oh well back to the machine shop. I will call the shop later today. Apparently the crank was not ground down for the .25 undersized bearings. All though the still look good, I may need new bearings and probably have to grind the crank. Maybe the standard size bearing will work. This is where a micrometer would have prevented all of this.
    I took pics up until the battery died on the camera. Will post them some other time.
    Meanwhile, I remove a Motorola CB Radio that was installed in the wagon and now I guess I will start working on the pedals. More to come.
    Hidden Content
