Page 18 of 23 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 223
  1. #171
    Aug 2008
    baltimore
    3,091
    The car isn't going to have any ignition without the STA and NSW circuits hooked up. Both get connected to E1-12 at least on an 85. Not sure if your ECU is an auto and if its like an Aristo 2JZGTE you need to switch the NSW connection or you'll get a soft rev limiter. If you have a CEL that at least means you have the ECU powered with +B and IGSW.
    did u try this one???
    Edgar M.
  2. #172
    Jul 2011
    Central Florida
    43
    I actually just have the NSW jumped, and I dont even know if that was necessary. I'm guessing that since it starts up with starting fluid it isnt an ignition issue. I'll look into that though. I'm going to get a noid light tomorrow and see if the injectors are getting switched power. Thanks
  3. #173
    Jul 2011
    Central Florida
    43
    It runs now. Evidently the pump was picking up some air because there wasnt enough fuel in the tank. Lol
  4. #174
    Aug 2008
    baltimore
    3,091
    Quote Originally Posted by 2jzcelica View Post
    FAIL
    Edgar M.
  5. #175
    Jul 2011
    Central Florida
    43
    Don't make fun of me, I wasn't the one who put the gas in the tank lol. http://s1118.photobucket.com/albums/...t=IMG_0676.mp4
  6. #176
    Oct 2005
    Norwalk, IA
    3,836
    Haha now that's some comedy this thread has needed in sometime. Glad you got her going.
    -Leon
    Random House Racing
    -1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm) JZA61 History thread
  7. #177
    ok i have 2 questions:
    1 I cant get my fuel pump to work by jumping the check connector. i have to run a wire from the battery to the pump. what am i missing?
    2 I have spark and fuel^ but no start..... could these be related?
  8. #178
    Aug 2008
    baltimore
    3,091
    Quote Originally Posted by jmbickley View Post
    i installed a switch in the dash w/ relay and fuse, basically the switch gets power from the ignition when the key is on.
    if you have fuel and spark, check your timing.
    Edgar M.
  9. #179
    ill try that im pretty sure timing is right.... ill check it again
  10. #180
    Oct 2005
    Norwalk, IA
    3,836
    Sounds like the ECU might not be getting the M-REL power source or something with M-REL as that would be on the same circuit with the Fuel Pump check connector as I recall.
    Random House Racing
id=a6141150">
