Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Nov 2006
    Spokane, WA
    7,862
    contour fan wiring problem
    got it wired in with this kit
    http://store.summitracing.com/partde...5&autoview=sku
    30-40 amp relay, and 30 amp inline fuse... wired in as per directions of kit
    and the inline fuse blows...
    turn car off replace fuse, and the second i hit the accesories switch on key, it blows again...is it because i grounded everything to the negative terminal directly??
    I checked for obvious positive/negative wire switches and there were none.
    gotta keep this short off to work,
    thanx for help
    Scott~~~85SDR5mgte Build Thread
    My Custom Valve Covers
    Sponsord by DIYautotune.com
  2. #2
    Feb 2007
    san antonio TX
    2,163
    ughh scott bigger fuse jk
    or wire it directly to the ignition so the come on when you turn the key
    1985 supra 66,000 miles 7mge, to many mods to list
    FOR SALE
  3. #3
    Apr 2007
    Quebec
    378
    Do you have an ohmmeter or a multimeter? If yes, check for continuity between the body and your 12v for the fan. IF you read 0 to 10 OHM or if you put your meter on the sound signal and you ear BEEEEEP. Than you did something wrong somewhere.
    Recheck your wiring and make sure all is ok.
  4. #4
    Santa Clara & Stockton, CA
    6,682
    The question is why do you blow the fuse when you turn the key on? The fans should be in the off position in this scenario. You wired something wrong on the fans and they are shorting out.
  5. #5
    Nov 2006
    Spokane, WA
    7,862
    figured it out...it was my grounds on my fan...each fan was directly grounded to the negative on the battery...
    now they are not and works great..
    these ford contour (threw that in there for help searching) fans really move air.
  6. #6
    Mar 2004
    Long Island, New York
    2,733
    so, just curious, how does the car feel without the clutch fan? rev faster? seem a little faster? or does it feel the same, just more space in the engine bay?
    '84 Supra
    '02 Ram 1500
  7. #7
    Nov 2006
    Spokane, WA
    7,862
    seems to rev a tad faster...
    but nothing spectacular...just feels more efficient.
    When sitting in place with the car running, the temp doesnt go any higher than when cruising at ~30.
    not to mention cleans up the look under the hood.
    overall well worth the money to me
  8. #8
    Nov 2006
    Spokane, WA
    7,862
    well for some reason its blowing the fuse again...
    i have been driving it and was working fine, not blowing the fuse, but now it is...
    the relay that came with it says 40/60 amp. the fuse is 30 amp.
    Do i need to get a bigger fuse??
  9. #9
    Nov 2006
    Spokane, WA
    7,862
    after reading this wiring diagram more closely
    http://forums.celicasupra.com/showth...contour+wiring
    it says that between the two fans they use 35 amps (roughly 17.5 a piece)
    i am running one inline 30 amp fuse. So should i step it up to a 40 amp fuse (as stated above the relay says 40/60 amp)
  10. #10
    Apr 2007
    Quebec
    378
    There is no problem to use a 40amp fuse but you need to be sure that your wire gauge is enough. Should be 8AWG for 40amp. If you have smaller wire, it could burn so its not safe.
id=a6141150">
