20R Front Main Seal
Results 1 to 4 of 4
    CelicaSupra.com Member
    Feb 2006
    Denver, Co
    512
    20R Front Main Seal
    Hey Mark,
    I'm changing the front main seal on a 20R motor in a 1980 4x4 Truck. People say that if the seal is old, it will wear a groove in the crankshaft so getting a thinner seal is best so that it seals on an un-grooved part of the crank.
    What engine/car will have a seal that will work?
    Thanks,
    Kyle
    P.S. Also, any idea what other seals commonly leak on this engine other than the valve cover (already doing that too)? Thanks
  3. #2
    2JZ in the hole
    ra24man's Avatar
    Jul 2004
    Vancouver, WA, USA
    3,656
    Use the late model 22RE seal (pn 90311-45014). It changes where the seal rides on the pulley so that you're running on a new surface. I'd go ahead and replace the oil pump o-ring while I'm there. As for leaks...oil pans are pretty common on the 20R, especially around the drain plug area, but outside of that they were a pretty good oil retainer. Leaky valve covers are due to substandard parts (Felpro for instance) or just being on there tooooo long.
    Main Seal $11.47
    Oil Pump O-Ring $8.08
    Thanks!
    Mark
  4. #3
    Oct 2006
    St. Cloud, MN
    3,708
    My dad used to have an '80 4X4 truck too. The distributor O-ring got hard with age and leaked, so you may want to check/replace that, too.
    Thanks for that info on the front seal, Mark!
    Hidden Content
  6. #4
    2JZ in the hole
    ra24man's Avatar
    Jul 2004
    Vancouver, WA, USA
    3,656
    NP...and yes, Distributor O-rings can go bad, but not nearly as often as front main seals do on this particular application.
    Mark
