Page 21 of 34 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 335
  1. #201
    Oct 2004
    Tigard, OR
    2,658
    How... the HELL did I miss this thread!! Awesome work!! What'd you get the ITB's from?
    And the bit about the Australians is true... I saw the video of the guy from Down Under that has a Rolls-Royce Merlin crammed into what used to be a 57 Chevy Bel-Air....
  2. #202
    Jan 2010
    Melbourne,Australia
    155
    That was me bevani, I was thinking back to the 350chev LJ's,460ford Rx4's,and who can forget Haddad's 532chev Capri I used to see at the street drags.
    Would it help if we threw some work at you crambo so you can finish your project?. I'd love to see and here that thing up and running. I need to get my A/C up and running in my mark 2 if you do car a/c.I'm out west past tulla airport. Keep goin man , it'll be worth it.How far are you from firing up the donk.Once you here that you'll smile so hard the top of your head will fall off.
    Luke
    ' 84 mk2 7mgte W58, extreme clutch, koni adjustable shocks, thick ass sway bars, aftermarket 12psi actuator, cometic HG, ARP head studs, microtech EMS, 2 1/2 exhaust, factory mk3 intercooler,
  3. #203
    Jul 2008
    Victoria Australia
    117
    To answer a few questions,
    The itb's are Toyota quads.
    I 've got some cash jobs (house a/c don't do car a/c) to keep the project going ok, just need the time to do it all.
    Hope it's running within 2 months (but I've been thinking that for a long time!!)
  4. #204
    Jun 2010
    Urbana, IL
    18
    This is truly inspiring. A real work of genius and art. Thanks for sharing!
  5. #205
    Jul 2008
    Victoria Australia
    117
    Genius I wouldn't say but pleasure and pain, hmmm, mostly pain at this point.
    I'm pleased to see people enjoy the folly.
    No pics ready for this post, wiring up an finding hoses.
    The Century up to 2005 had the hydraulic cooling fan, then switched to twin electric fans, in a week I should have the casting with the idler pulley to take the place of the hydraulic pump on the left side head, at last I can put my accessory belt on.
  6. #206
    Jul 2010
    Idaho
    2
    I see nothing wrong with the TPS sensors staying, while the throttle actuators go in the garbage. I say this assuming a stand alone system could give you the PWM's to still use any VVTi if equipped? I noticed that the throttles have the expected coolant lines under them but no idle control valve as they already have motors. A Toyota idle valve could be plumbed in nicely. When I saw these pictures in image search, I literally had chills. Screw the stock algorithms that buffer throttle input. If you have a V12, then then providence from the Horsepower Gods must not deny you the chance to snap open the lungs on that f@#ker! I think I'm getting light headed.
  7. #207
    Jul 2008
    Victoria Australia
    117
    Unfortunately, to make it road legal here, it must have all the pollution gear including stock ecu's, with that the DBW.
    After it's licenced/registered you can do stuff but it still won't be legal, we'll see, first hurdle is to get it past engineers.
  8. #208
    Sep 2008
    Curaçao
    45
    Was a long time since I visited this thread. Good to see it's making progress. More power to you!
  9. #209
    Spring Hill, Fl.
    13,963
    Quote Originally Posted by Crambo View Post
    Happy with the black
    Got an adaptor plate, looking at a new to the market 9" twin plate, hope to sort this out soon, this has been an irritation for way too long!!!
    got more pics of this adaptor? does it bolt the trans to an a340e bellhousing? thats what it looks like. and your t56 is an lt1 t56 correct? or is it an ls1 trans?
    william
  10. #210
    Jul 2008
    Victoria Australia
    117
    The adaptor pattern is what would be used for a 1UZ as the box end of the bell is the same although the V12 bell is a little longer.
    The T56 was for LS2, the input shaft the is short variety, the longer version would be better.
    Been a bit distracted with other stuff the last month but hope to be on top of the wiring asap.
    I'll put up pics when a bit more is sorted.
    I have been looking at tail lights and found some Mitsubishi ones but not many of these cars wrecked yet, a new set $1k+
    Always a problem as the rear end is so flat compared to modern cars so curved, got some USA GM lights in mind too.
id=a6141150">
