Oversized valves? - Page 7
Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
  1. #61
    CelicaSupra.com Member Wolfgang's Avatar
    Sep 2004
    Vancouver BC
    552
    I am with Billy on this. I want to see a dyno sheet for a 300 hp 6m. If true, 1.7 horsepower per cubic inch is pretty impressive..
    85 Supra, Red, Auto, 300k. Chimpy 6M. MHG & ARPs. 60-1 Trim, Stainless Lines, Q45 Brakes, 16's, Al Rad+E fan, Oil kit and cooler, MSD 6a + Accel Coil ms2 3.57... Air shocks and coil overs in the works.. Maybe a mk3 trans next........
  3. #62
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    12,797
    It doesn't exist...
    --billyM
    White 85P - Blue/Silver 85P
    Hidden Content
    Hidden Content
  4. #63
    Spring Hill, Fl.
    14,687
    has anyone flowtested a stock 5mge head with stock valves and then flow tested a ported 5mge head with oversized valves? im curious to see the numbers. i have the ported head that came with my hks cams and weber intake etc.. and a set of oversized valves, but havent gotten the head machined for the valves and wouldnt have the money to have 2 heads flowed to compare them. still need to send the hks cams out to be spec'd and repaired as well.
    william
    Hidden Content blue 85 beater
  6. #64
    Jul 2006
    Santa Babrara
    687
    From what ive learned from talking to engine builders is that 1mm over sized valves do not really flow more they are that way to make sure u can get a proper valve seat if the seat is damaged. If you wanted more flow you would need bigger then 1mm. the amount of flow difference would be so small for the for the cost of valves and money for work to get them put in. this is coming from people that use a flow bench. better off spending money on cams. and if its forced induction turn up the boost ull get more air in there.
    Engine: 7mge with a T
    Suspension: Worked
    Brakes: Solid
    Hidden Content
  7. #65
    Spring Hill, Fl.
    14,687
    the oversized valves for the 5m made by engbuilser on ebay(the ones i have) are larger then 1mm difference. the 7mgte valves are 1mm difference. but the 5m are larger. also, the valves are back cut which also increases flow. either way i have them and will use them. maybe ill get lucky and find a machine shop that will flow both setups for cheap when im able to get the machine work done. in the mean time. if they are somewhere easy to get to, ill try to measure them with my dial caliper. then ill look up the stock valve size specs in the tsrm to compare to.
    william
  8. #66
    Jul 2006
    Santa Babrara
    687
    ahhh i was thinking they were just 1mm. have 7m now so only have the .5 and 1mm bigger that ive seen. for the money and what i was told i would get out of it was not worth it. atleast with the 5m you only have 12 valves. i thought i read on here a long long time ago about some one modding up some chevy valves to make them work and they were quite a bit bigger. needed to shorted the shaft lenght or something and put a new grove for snap ring. I could be wrong though might have been my buddies 240z that had chevy valves put in it.
    Suspension: Worked
    Brakes: Solid
    Hidden Content
  9. #67
    Supra since '86 rsdeo's Avatar
    Apr 2003
    Burlington, Ontario. Canada
    5,463
    Oversized HKS valves in a 5M, from here. I have never seen these listed anywhere.
  10. #68
    Banned
    Jul 2012
    london
    4
    Oversized valves?
    Hi guys please tell me what is oversized value ? And also his work...
