How to clean out your EGR system. (56k beware) - Page 8
Page 8 of 8 FirstFirst ... 678
Results 71 to 74 of 74
  1. #71
    May 2005
    N. Seattle.
    4,306
    Well,after all of that work to unplug the passage,the engine will not "BOG" when I manually open the EGR valve,Jim.
    See the PIX above.
    I added a 4/40 bolt with an O ring in the middle of the freeze plug,so I could force feed some cleaner in there ,when I wanted to.
    I made this out of a plastic syringe and a valve used to inflate basket balls and I injected some Techron in there until the engine died and let it sit overnight.
    Didn't work.
    Maybe black powder gun cleaning solution would by pass the need to pull that damn thing apart again.
    Same method.
    About 1,000 cc's may do it.
    Maybe the passage is blocked just passed the EGR valve.
    The gun shop in Wenatchee,WA didn't have black power(Sorry) gun cleaning solvent.
  3. #72
    Aug 2013
    SoCal / Long Beach
    2,936
    "Hoppe's #9" or Birchwood-Casey "Gun Scrubber" should work equally well to dissolve carbon deposits.
    My EGR valve was clean, the passage wasn't too bad, but the little brass "spout" tube that directed the exhaust gas flow to the throttle body was packed solid.
    The crud came out easily, but it surprised me that that was the only place I could find that had an obstruction.
    1985 5-speed "Ms. Swan"
    OH, What A Feeling!
  4. #73
    CelicaSupra.com Member SupraMoto's Avatar
    Apr 2003
    Victoria, B.C. Canada
    229
    Heres what I found inside my EGR, some was dry, and some was gooey (towards the intake where fuel is).
    '83 Black P-Type
    My threads:
    -- Hidden Content
    -- Hidden Content
  6. #74
    Junior Member
    Jan 2017
    CA
    4
    Thank you for this DIY! Hopefully it will allow me to pass smog!
