stock 5M-GE cam specs and valve spring sizes
Results 1 to 4 of 4
    CelicaSupra.com Member 85TurboMKII's Avatar
    Largo, FL (Near Tampa)
    430
    Does anyone know the stock cam specs for a 5M as well as the size of the valve springs? I will be doing a rebuild on my 6M shortly and I might potentially be able to have brand new cams made from blocks of billet aluminum. yes this would be creating cams from stock adn making the blanks and going from there. I"ll see what happens if I can find the stock specs.
    Eric
    1985 67MGTE, Addco sway bars, ST springs, Koni Shocks, LJM strut bar, Lewitz rear bar, ARP head studs, HKS MHG, Ross Forged Pistons
    8.87@79mph (untuned)
  3. #2
    Santa Clara & Stockton, CA
    7,480
    Camshafts need to be made from hardened steel, not aluminum. Maybe it was a typo but aluminum is a lousy wear material and too soft for cam duty.
    1985 Super Silver Supra 2JZGTE
    2013 Satin White Pearl BRZ FA20
    2001 Black Sand Pearl Corolla 1ZZFE
    "You can never go fast enough....."
  4. #3
    430
    they are also available in steel....I am still working out the details...and I'm probably going to have to send him a couple of cams yet but it's a friend of my roomates up in I think maryland. my roomate builds old pontiac's and this guy has made cams from scratch for him before and I'm talking 9 second cars here. so they must be strong enough.
    Quote Originally Posted by SilverMk2
    Eric
  6. #4
    CelicaSupra.com Member AJ's Avatar
    SF Bay Area
    6,399
    Eric, check out the aftermarket regrinds below, should give you some idea of cams specs for the 5mge and be sure to check out the TRD CAMS thread on the CS.com forum:
    http://www.elgincams.com/
    http://www.schneidercams.com/
    http://www.deltacam.com/
    7mge specs:
    http://www4.tpgi.com.au/users/loats/...camshafts.html
    I have some info but not sure if I wrote it down correctly??
    cam seat duration .235
    duration @ .050 .188
    Intake lift .218
    Exhaust lift .221
    Regards,
    Arch
    '86 Supra MA67
    Brullen 2.5" Exhaust, HKS Fly w/7MGE clutch,ST Springs, RC Intake & TB, 2.8GT & XX emblems, Factory Add on Rear Shoulder belts, Pioneer DEH-P2000 AM/FM/CD w/CDS-P5000 CD Player, Compomotive CXNs 8x16
