Results 1 to 10 of 16
04-16-2009, 12:49 AM #1
Raptor Racing MK2 Exhaust Products Catalog
Please see this Post for Details on what the 'Notes' Mean and if you're Canadian be sure to read the bottom of the post.
Raptor Racing 2.5" Cat Back System *FREE SHIPPING*
Price:$545
Part Number: Raptor-MK2-2.5”CatBackSys
Notes: In Stock - please check to ensure powdercoated muffler is in stock...they usually are but good to check with us anyway.
These 2.5” Raptor Racing Cat Back Exhaust System comes with Polished Stainless Steel piping. All cat back piping comes with a resonator; plated nuts/bolts/washer; 2.5 torctite clamp and gaskets. You won't have to go to your local muffler shop to install this; it's a bolt in system. Depend on the muffler you order lead time to have the product shipped out ranges from 1 day for cat back piping only to 2 weeks if you need a powder coated muffler. We regularly stock powder coated muffler so this won’t always be a problem but I just want to be clear that if it’s not in stock it takes at least 2 weeks to get the muffler ‘built’ and coated.
These systems is designed for cars that utilize 12.5” cats; if your vehicle uses a 17.5” cat you will HAVE to purchase a 12.5” cat in order to make this system work on your car. In order to keep costs down I will not build separate systems; both have the same mounting point to the header/downpipe so as long as you get/have the appropriate cat/test pipe it's all the same.
Black Wrinkle Powder coating can be added; please select whether you like to a plain or powder coated muffler with the drop down menu.
Muffler:
• Polished
• Wrinkle Black Powder coat +$60
Raptor Racing 3.0" Cat Back System *FREE SHIPPING*
Price:$545
Part Number: Raptor-MK2-3.0”CatBackSys
These 3.0” Raptor Racing Cat Back Exhaust System comes with Polished Stainless Steel piping. All cat back piping comes with a resonator; plated nuts/bolts/washer; 3.0" torctite clamp and gaskets. You won't have to go to your local muffler shop to install this; it's a bolt in system.
Our systems come with a modified Magnaflow Twin Tip Muffler. We have expanded the input to 2.5" and welded on a hanger for easy of installation. Depend on the muffler you order lead time to have the product shipped out ranges from 1 day for cat back piping only to 2 weeks if you need a powder coated muffler. We regularly stock powder coated muffler so this won’t always be a problem but I just want to be clear that if it’s not in stock it takes at least 2 weeks to get the muffler ‘built’ and coated.
Muffler:
• Polished
Raptor Racing 3.0" Catback Piping Only *FREE SHIPPING*
Price: $300
Part Number:Raptor-MK2-3.0”Piping
Notes: In stock
These 3” Raptor Racing Cat Back Exhaust System comes with Polished Stainless Steel piping. All cat back piping comes with a resonator; plated nuts/bolts and washers. You won't have to go to your local muffler shop to install this; it's a bolt in system.
This system is designed for cars that utilize 12.5” cats; if your vehicle uses a 17.5” cat you will HAVE to purchase a 12.5” cat in order to make this system work on your car. In order to keep costs down I will not build separate systems; both have the same mounting point to the header/downpipe so as long as you get/have the appropriate cat/test pipe it's all the same.
Raptor Racing 2.5" Catback Piping Only **FREE SHIPPING**
Price: $275
Part Number: Raptor-MK2-2.5”Piping
Notes: In Stock
These 2.5” Raptor Racing Cat Back Exhaust System comes with Polished Stainless Steel piping. All cat back piping comes with a resonator; plated nuts/bolts and washers. You won't have to go to your local muffler shop to install this; it's a bolt in system.
Raptor Racing Modified Magnaflow Mufflers *FREE SHIPPING*
Price: $290
Part Number: Raptor-14815
Before we set out to have our own cat back systems made for MK2's and MK3's we desperately need a muffler. But not just any muffler; we wanted a muffler that was very period specific: long oval design and twin dual wall tips. Stainless construction was a must as was build quality and manufacturer support.
After months of looking we finally stumbled upon our solution. We always LOVED the look and sound of Magnaflow 14815 and 14816 dual tip mufflers but there was a problem: the input is only 2.25. Hardly doable for turbo application and barely doable for N/A builds. While at our suppliers warehouse we peeked in a box and noticed something unique to these 2 mufflers: twin tubes running the length of the muffler. This means not 1 but 2x2.25" tubes running the length of the muffler extending out to the tips.
Solution: Cut off the 2.25" input at the base; CAREFULLY expand it out to 2.5 or 3 inches; weld in the appropriate section of pipe and BAM: a new muffler is born.
You may think this is a lot of trouble to go through; but when you're as picky as we are it's all in a days work. If you want to for that really old school look at wrinkle black powder coating to your order; TRUST us you won't be sorry.
Please note this muffler was designed to fit the piping for the Raptor Racing Catback systems. While we can guarantee that the hanger is in the correct location we cannot guarantee it will work with any other system.
Muffler Finish:
• Polished
Muffler Input
• 2.5” Input
• 3.0” Input
Raptor Racing 2.5" High Flow Metallic Spiral Core Catalytic Converters
Price: $180 for 12.5" and $220 for 17.5"
Part Number: Raptor-MK2-2.5”Metallic
Notes: In stock
In order to complete your exhaust upgrade replacing your 25+ year old catalytic is something you should strongly consider. After all; you've spent good money on a quality exhaust system that is now restricted by a clogged quarter century old cat. For those who mind only knows 2 letters…HP: the Spiral Core metallic cat is the way to go. With cells virtually twice as big as ceramic core cats you can be rest assured that these cats aren't robbing you of the HP you deserve.
Each cat is hand polished; comes with stainless flanges; plated hardware and gaskets. At Raptor Racing we want to ensure when you get your product it's ready for install; what's the point of buying a cat from another vendor if they're charging you for hardware and gaskets. With us it's all included so fear not.
Raptor Racing 3.0" High Flow Metallic Spiral Core Catalytic Converters
Part Number: Raptor-MK2-3.0”Metallic
Notes: In Stock
Raptor Racing Divorced Downpipe *FREE SHIPPING*
Price: $575; $500 with Cat Back System Purchase
Part Number:Raptor-MK2-DDP
Notes: IN STOCK
For those of you not familiar with the concept of divorced downpipes I will explain it briefly. The theory behind this is that by separating the paths for the turbine and wastegate you are creating less turbulence in the elbow region…less turbulence=greater efficiency; greater efficiency=more power…more power=if I have to tell you this please don’t buy this…J/K
By using a Raptor Racing Divorced Downpipe along with a Raptor Racing Cat back system (with a test pipe); Mike Malloy (owner of www.celicasupra.com ) was able to go from 225rwhp(239lb-ft) with a 'stock' setup to 267rwhp(280lb-ft) on a Mustang Dyno.
This is without a doubt the finest and most powerful downpipe you can get for your MK2. Don't accept copies; we have spent dozens of hours and thousands to ensure this downpipe fits your MK2 like a glove, works with 5m, 6m and 7m motors.
Raptor Racing 6 into 1 Header *FREE SHIPPING*
Price: $450; $415 with Catback System Purchase
Part Number:Raptor-MK2-Header
Notes: NOT in stock.
If you want to really unleash the beast under the hood a Raptor Racing 6 into 1 is going to best ammunition you can get. Our header is the ONLY 5/6/7 header out there that can claim without a shadow of a doubt a 10rwhp increase.
Raptor Racing wanted to ensure that before we released this header for sale that it would perform as good as it felt. So back in 2006 one of the local clubs had a dyno session, our first thought: "wow…witnesses".
So what we did was Dyno the car with the header, let the car cool off...take off the header and put on the factory manifold and re-dyno. Our thinking from the beginning has been that's it's always best to do testing on the same day in similar conditions. This way you can without any doubt be confident at the results you are claiming.
We'll let the dyno speak for itself; here are the mods on the car at the time of the dyno:
• Raptor Racing 6 into 1 Header (on the one run only)
• Raptor Racing Magnaflow Cat
• Raptor Racing 2.5" Cat Back
• Raptor Racing Modified Magnaflow Muffler
• 3" Rabid Chimp 'style' Intake and Generic 3" Air Filter
• 12 degrees timing on a 5m Motor
Don’t' let anyone tell you again that a 6 into 1 header will lose power down low. As my good friend Seamus pointed out: "This header gave up nothing to the factory manifold". No expense has been spared when testing/making this manifold. It was installed on our car; driven for over 750miles; dyno tested; given to Dean Anderson to get his approval and it's finally up for sale. If you can find another header that has gone through such rigorous and documented testing that has these results let us know and we'll gladly take down our claim as the ONLY header with a properly documented before and after dyno.
Product Details
• 6 into 1 Design made with Mild Steel
• Professionally Ceramic Coated inside and out.
• Includes: all gaskets and plated hardware
• Shortened factory o2 bung - your o2 harness MUST be extended
• Wideband o2 bung (Currently this bung is not useable so we will loctite the nut on so it doesn't slip off). Our next run of this header will have this corrected.
• Full 2.5" Downpipe
Raptor Racing 2.5" Stainless Test Pipe *FREE SHIPPING*
Price:$85 for 12.5" or 17.5"
Part Number:Raptor-MK2-2.5”TestPipe
Notes: In Stock
Just as beautiful as our cat back piping; our off-road test pipe comes in polished stainless steels. Much like our cat you will also receive plated hardware and gaskets.
Raptor Racing 3.0" Stainless Test Pipe *FREE SHIPPING*
Price: $85 for12.5" or 17.5"
Part Number:Raptor-MK2-3.0”TestPipe
Notes: In Stock
5m/6m/7m O2 Gasket *FREE SHIPPING*
Price: $10
Part Number:Raptor-O2-Gasket
Notes: In Stock
When it comes time to replace your O2 gasket we've got you covered. Our Toyota O2 gasket is a metal gasket that has thick paper in the middle to help with sealing. Why not pick a couple up as you never know when you'll need a spare.Last edited by RaptorRacing; 11-21-2012 at 09:49 PM.
05-10-2009, 09:21 PM #2
CelicaSupra.com Member
- Join Date
- Jul 2007
- Location
- Dallas Center, IA
- Posts
- 986
I just got my 7M GTE mk2 running fully yesterday. We modified my DP. I bought the 3" SS Cat Back with the Magnaflow. The exhaust was 100% worth it. I origionally questioned whether it would be easier to get different pieces of pipe and weld them all together or buy 3" SS exhaust from RR and just modify the DP. It took us about an hour to do the exhaust. Took me 10 minute to hang the exhaust from RR. Took 20-30 to mock up how the DP would go. Ok... it took less than an hour. The exhaust sounds awesome. Love it!
Thanks RR,
TonyLast edited by Suprasaurus; 05-15-2010 at 04:23 PM.
05-10-2009, 10:19 PM #3
Awesome Tony...thanks so much for your feedback and more important your business.
05-15-2010, 11:23 AM #4
First post updated; unfortunately the pricing of the mufflers has gone up on my end. Sorry guys I've been trying to keep that cost down as much as I can but some things are beyond my control.
07-12-2010, 12:42 PM #5
- Join Date
- Dec 2009
- Location
- North Dakota
- Posts
- 304
I had my RR 2.5 Catback w/test pipe installed this past weekend. The system and the muffler looks great. A little loud on the highway (for an old man like me), but the sound around town more than makes up for it. Great product and great service, thanks George.
- '85 MR2
- '85 Supra P type
- '02 WRX wagon
09-09-2010, 01:12 PM #6
1st post updated: Ceramic cats have been taken out of my catalog. Stocking Ceramic and Metallic cats in 4 different varieties (MK2 2.5" and 3"; MK3 2.5" and 3") is difficult and hard to keep them all in stock; to simplify things for me the ceramics have been taken out of the catalog. If someone seriously wants one I can still get it made but pricing wont' be the same as before as making them one at a time vs. 5 at a time is more costly.
07-23-2012, 07:33 AM #7
Any update when the 3" exhaust piping will be back in stock?
07-25-2012, 10:19 PM #8
No update...fall time for sure as I have other projects that I'm working on now...sorry.
09-01-2012, 01:31 PM #9
You still make a 7m T-4 manifold, George?
Austin Easley
1984 Light blue Mkii
09-01-2012, 03:43 PM #10
Nada...on the "to do" list but nothing in the near future.
