Results 1 to 10 of 118
04-16-2009, 01:32 AM #1
Raptor Racing MK2 Suspension Products Catalog
Please see this Post for Details on what the 'Notes' Mean and if you're Canadian be sure to read the bottom of the post.
K-Mac Caster/Camber Plates Stage 1 *FREE SHIPPING*
Price:$375
Part Number:KMAC-MK2-761316S1
Notes: 2 sets in stock
If you think these look and perform the same as any other upper mounting plate out there you are sadly mistaken. These are different than the Cusco and the T3 Kits in that they allow you to adjust camber AND caster. Cusco and T3 only allows you to adjust the Camber.
Another advantage to most street users is that the mount is Urethane as opposed to a solid aluminum mount (on stage 1 and 2 units). Solid mounts are great but they transfer every little vibration on the road back to you...the urethane bushings absorb a lot of the road while still providing tight handling characteristics. Since 99% of you use your car on the street I would say that this is a huge advantage. While it's true that the factory rubber bends and flex's far too much; on a street setup some bending and flexing makes for a more pleasant drive.
If you're not interested in having the ability to easily adjust your caster and don't mind the 'harsher' rides of the Cusco/T3 units than stick with those... because of the added adjustability these units are a little pricier.
A couple of other key points to note according to K-Mac:
EASE OF FITMENT - Bolt-on, simply replacing the top strut mounts
(Single units - no loose parts)
EASIEST / QUICKEST TO ADJUST - (both Camber and Caster). Simply loosen the strut top mount nuts and adjusting accurately under load (another K-MAC patented feature) from engine bay, direct on alignment turntable - no need to jack vehicle.
MAXIMUM ADJUSTMENT RANGE
Unlike the existing twin slot designs that have been around for years, with the
K-MAC design there's no need for the extra hold down bolts thereby allowing increased adjustment range (both Camber and Caster) and not requiring the twin slots – there's greater strength to withstand high impact loads.
These Units come in 3 Stages:
Stage 1: Street/Semi Race - Captive Ball Race with Urethane
Stage 2: Street/Race - Pillow Ball with Urethane
Stage 3: Race - Solid Pillow Ball (no urethane)
K-Mac Caster/Camber Plates Stage 2 *FREE SHIPPING*
Price: $475
Part Number: KMAC-MK2=761316S2
Notes: 2 Sets in stock
K-Mac Caster/Camber Plates Stage 3 **FREE SHIPPING**
Price: $475
Part Number: KMAC-MK2-761316S3
See Description Above.
TechnoToyTuning Camber Adjusting Plates *FREE SHIPPING*
Price: $202
Part Number: T3-MK2-Camber
Notes: Drop-Shipped from Supplier HEAVILY Stocked
Features
• Steel plates with Aluminum center blocks
• Precision Oversized spherical bearings
• Bearings are Teflon lined and self lubricating
• Comes with all mounting hardware and new upper nuts for mounting in the strut tower.
• Machined T3 Logo and tick marks for marking your camber settings
The bearings on these are inserted into the aluminum blocks with what is called an "interference fit". What that means is that the holes that the bearings go into are actually a hair smaller than the bearing going into them. What we do is freeze the bearings and heat up the aluminum blocks to 200 degrees. This makes the bearings shrink a bit and the blocks expand a bit, and then they slip right in!
Once the temperature equalizes on both, those bearings are IN THERE! They will not move around or cause you any "clunking" noises. They are also held in by a keeper ring, to ensure they don't pull out of the bottom of the blocks.
TechnoToyTuning Needle Bearing Set *FREE SHIPPING*
Price: $70
Part Number: T3-MK2-Needle
The Camber Plate Upper Hat System is available for any car using coilovers. It can also be utilized with most other camber plates on the market, including Cusco and Cusco-Clone camber plates.
Camber Plate Upper Hat System consists of 2 upper hats, 2 hardened washers, 2 needle bearings and two upper race washers.
Whiteline MK2 27mm Front Adjustable Swaybars **FREE SHIPPING**
Price: $237.54
Part Number: Whiteline-MK2-BTF76Z
Notes: Drop Shipped from Supplier, probable long wait if Not in stock so please check with us.
Back in 2006 we realized a severe lacking of quality suspension components for the MK2; so we contacted Whiteline and asked them to design and build adjustable swaybars. The rest as they say is history; the front Whiteline Adjustable for the MK2 are 27mm and can be adjusted 3 ways per side. Each kit comes with all the parts you'll need: Adjustable Swaybars; Endlinks; hardware and brackets. There is nothing else to purchase. We believe that this is the single most important upgrade you can do to your MK2 as nothing can tune the over/understeer of your car more than adjustable swaybars.
Don't forget to purchase a rear adjustable bar too for ultimate suspension tuneability.
Whiteline MK2 18mm Rear Adjustable Swaybars **FREE SHIPPING**
Price:$187.06
Part Number: Whiteline-MK2-BTR21Z
Back in 2006 we realized a severe lacking of quality suspension components for the MK2; so we contacted Whiteline and asked them to design and build adjustable swaybars. The rest as they say is history; the rear Whiteline Adjustables for the MK2 are 18mm and can be adjusted 3 ways per side. Each kit comes with all the parts you'll need: Adjustable Swaybars; Endlinks; hardware and brackets. There is nothing else to purchase. We believe that this is the single most important upgrade you can do to your MK2 as nothing can tune the over/understeer of your car more than adjustable swaybars.
Don't forget to purchase a front adjustable bar too for ultimate suspension tuneability.
Superpro SPF0307K Strut Rod Bushing
Price: $35.33
Part Number: SP-MK2-SPF0307K
Notes: In Stock
Bushing Replacement on your Supra is the most overlooked upgrade. Quality bushings can improve steering response, and retain consistent alignment settings, which will improve overall handling. Each SuperPro bushing application has been developed with a specific durometer (hardness) to ensure proper performance and product life.
Superpro SPF0307K is used to replace factory rubber strut rod to chassis bushings. 1 package is all you need for do both sides, ample grease is included with each kit.
Superpro SPF0509K Front Control Arm Bushings
Price:$31.04
Part Number: SP-MK2-SPF0509K
Notes: In Stock
Superpro SPF0509K is used to replace factory rubber Front Control Arm Bushings. 1 package is all you need for do both side; ample grease is included with each kit.
Superpro SPF0903K Front Swaybar Endlink Bushing Kit
Price: $19.82
Part Number: SP-MK2-SPF0903K
Notes: in Stock
Superpro SPF0903K is used to replace factory rubber Front endlink bushings. 1 package is all you need for do both sides. Please note that this kit cannot be used with the Whiteline adjustable swaybars.
Superpro SPF1213K Rear Control Arm Bushings
Price: $82.74
Part Number: SP-MK2-SPF1213K
Notes: in Stock
Superpro SPF1213K is used to replace factory rubber rear control arm endlink bushings. 1 package is all you need for do both sides, ample grease is included with each kit.
Superpro SPF1447K Rear Cross Member Bushing
Price: $143.07
Part Number: SP-MK2-SPF1447K
Notes: in Stock
Superpro SPF1447K is used to replace factory rubber rear cross member bushings. 1 package is all you need for do both sides, ample grease is included with each kit.
Superpro SPF2926K Rear Subframe Bushing
Price: $123.25
Part Number: SP-MK2-SPF2926K
Notes: NOT in Stock
Superpro SPF2926K is used to replace factory rubber rear subframe (diff mount) bushings. 1 package is all you need for do both sides, ample grease is included with each kit.
Superpro SPF0903-4K Rear Swaybar Upper Endlink Bushings Set
Price: $16.37
Part Number: SP-MK2-SPF0903-4K
Notes: in Stock
Superpro SPF0903-4K is used to replace factory rubber rear upper swaybar endlink bushings. 1 package is all you need for do both sides. Please note that this kit cannot be used with the Whiteline adjustable swaybars.
Superpro SPF0280K Rear Swaybar Lower Endlink Bushing Set
Price: $22.41
Part Number: SP-MK2-SPF0280K
Notes: in Stock
Superpro SPF0280K is used to replace factory rubber rear lower swaybar endlink bushings. 1 package is all you need for do both sides. Please note that this kit cannot be used with the Whiteline adjustable swaybars.
Superpro SPF2755SK Rear Upper Shock Bushings
Price: $15.51
Part Number: SP-MK2-SPF2755SK
Notes: in Stock
Superpro SPF2755SK is used to replace factory rubber rear upper shock. 1 package is all you need for do both sides.
Superpro SPF2178-16K Rear Lower Shock Bushings
Price: $14.65
Part Number: SP-MK2-SPF2178-16K
Notes: in Stock
Superpro SPF2178-16K is used to replace factory rubber rear lower shock bushings. 1 package is all you need for do both sides, ample grease is included with each kit.
KYB AGX Kit - Wes Hetrick Mod *FREE SHIPPING*
Price: $424.99
Part Number: KYB-MK2-AGX
Notes: Drop Shipped from Supplier MIN 2 weeks Transit Time
Thanks to Wes Hetrick the MK2 crowd now has a quality solution to adjustable suspension. This kit includes 2nd Generation MR2 Struts and Ford Focus Shock; along with a package of Superpro SPF2178-16K lower shock bushings AND Raptor Racing’s Strut Tube spacer which in our opinion is the best way to Install these if you’re not going to cut your strut tubes.. Wes was kind enough to do a write up to explain what is needed to be done in order to have these installed:
http://www.tscperformance.com/supra_frontstrut.htm
http://www.tscperformance.com/supra_rearagx.html
Please note that Raptor Racing provides you with all the parts necessary to do this mod but it's up to the customer to install the rear shock bushings. Also Raptor Racing no longer supplies the washers to get this done, we HIGHLY recommend the use of the part below
Raptor Racing STS + KYB AGX Kit - Wes Hetrick Mod *FREE SHIPPING*
Price: $489.99
Part Number: KYB-MK2-AGXSTS
Thanks to Wes Hetrick the MK2 crowd now has a quality solution to adjustable suspension. This kit includes 2nd Generation MR2 Struts and Ford Focus Shock; along with a package of Superpro SPF2178-16K lower shock bushings.. Wes was kind enough to do a write up to explain what is needed to be done in order to have these installed:
Raptor Racing Product: AGX 765016 Strut Tube Spacer
Price: $77usd Shipped to the USA
Part Number: Raptor-MK2-STS
Notes: Heavily stock in Canada and US Supplier
You guys asked for it and now you got it; we have joined forces with T3 to finally bring you a MK2 Specific Strut Tube Spacer.
These will work with the widely used KYB 765016 AGX MR2 Strut Cartridge. Anyone who has seen T3's AE86 equivalent part can confirm its a fine piece of work
Benefits of this over washers can be found in this thread.
KYB MK2 Rear Gas-a-Just Rear Shocks (pair)
Price: $77.50
Part Number: KYB-MK2-KG5561
For those looking for a rear shock that is more robust than your standard KYB GR2 than the GAS-a-JUST is what to get. Please note that these are NOT adjustable, don't let the name fool you.
KYB Gas-a-Just shocks use higher gas pressure to keep your tires glued to the road. The KYB Gas-a-Just shocks' velocity-sensitive valving system adjusts quickly to changing road conditions for maximum comfort in any situation. Their monotube configuration eliminates aeration and foaming, their micro-smooth, hard-chromed pistons extend their life, and their seamless cylinders and eyerings completely eliminate seam failures.
Pricing is per pair.
KYB MK2 Front GR2 Struts
Price: $97.50
Part Number:KYB-MK2- 365076
If you're looking to replace your aging suspension on a budget than the GR2's are your best bet. You won't find a better setup for this kind of money; however if you're planning on doing more than average track use with your car you might want to consider something else.
KYB's GR2 Series shocks and struts are specially designed to deliver moderate handling. A patented check valve minimizes foaming and aeration to make sure the ride is stable, even under rough conditions. GR2 shocks and struts are a low pressure gas twin tube design. Good for normal to moderate performance driving.
• Velocity-Sensitive valving
• Hardened chrome piston rods
• Twin-tube design
• Multi-lip seals
• Check valve to eliminate foaming
• Low pressure Nitrogen gas
• Iron pistons and guide rods
• Seamless tube body
KYB MK2 Rear GR2 Shocks
Price: $61
Part Number:KYB-MK2-343042
• Twin-tube design
• Multi-lip seals
Dobinson MK2 Front Lowering Springs
Price: $170
Part Number: Dobinson-MK2-C59070
Notes: In Stock
These springs are cataloged as a standard height spring by Dobinson but they actually lower your MK2 by approximately 1". This allows for plenty of clearance while still giving your MK2 that aggressive look and tight handling you desire. These springs are use by dozens and dozens of members on CelicaSupra and feedback is VERY positive.
**PLEASE NOTE** All Dobinson Springs come in Black Now**PLEASE NOTE
Dobinson MK2 Rear Standard Height Springs
Price: $170
Part Number: Dobinson-MK2-C59063
Notes: In Stock
This is a brand new product that was previously not available before (Spring ’09). We worked very close with Dobinson to finally make a P-Type Standard Height Spring. After a prototype was made was flew it to North America where it was tested by www.celicasupra.com member Dangerous Ken. The result is shown in the pictures below; this is a 90,000mile mk2 with factory springs in the top pix and the new Dobinson’s in the bottom pix. This new springs ensures you won’t have that 80’s Z28 look while still maintaining very close to factory camber.
We all know what happens when you lower your MK2 too far: extreme negative camber. Unless you're willing to weld in a rear camber adjusting kit installing rear lowering springs will give you more negative camber than your tires can handle. Dobinson Standard height springs are the perfect solution for a performance spring that will keep your rear Camber in check; your tires will thank you.
Dobinson MK2 Rear Lowering Springs
Price: $170
Part Number: Dobinson-MK2-C59059
Notes: In Stock
This is a brand new product that was available before, however the specs on this spring were far too extreme for most people. The old C59-059 from Dobinson was 65mm(2.5”) lower than the standard height Dobinson. We contacted Dobinson and suggested a change to the product and they agreed, so the new C59-059 is now 320mm free height vs. 295mm before. This sprint is now 20mm(0.78”) lower than the new 340mm standard height Dobinson. We felt that this was perfect for those that wanted a slight drop in the rear without dramatic changes to camber.
We only sell Dobinson springs for the MK2 because we believe it’s crucial to support companies who are will to cater to such a small market. A couple quick email and one phone call and we were able to completely change the specs one of their springs.
Dobinson MK2 300lb Rear Lowering Springs
Price: $170
Part Number: Dobinson-MK2-C59065
Notes: In Stock
This is a brand new product that was available before, this new spring is perfect for those people with front coilovers in the 400-450lb and need a drop in 300lb rear spring. The drop on this spring will be identical to the Dobinson Lowering Spring for the MK2 seen in this thread. I’m not linking the pictures because I’d like you to read the thread before looking at the pictures so you know what you’re looking at.
TechnoToyTuning Roll Centre Adjusters *Free Shipping*
Price: $102
Part Number:T3-MK2-RCA
T3 RCAs (Roll Center Adjusters) are designed to get rid of that pesky bump steer on your lowered vehicle. The alignment sleeves are solid milled into the unit, so they will not get lost or come off. We also added a larger alignment ring for the center of the unit, to provide even more shear protection than other RCAs on the market. These RCAs will NOT move or become mis-aligned, no matter how hard you drive. Comes with all mounting hardware - four new grade 8 bolts and lock washers.
TechnoToyTuning Strut Rod *Free Shipping*
Price:$234
Part Number: T3-MK2-StrutRod
• All solid steel construction
• All hardware plated or powder coated providing a finish tough as nails.
• Solid 1" steel, single piece arm design, providing the maximum in rigidity
• Three piece precision rod ends with 3/4" shank, and 5/8" bore, making them INCREDIBLY strong. The rod ends are also Teflon lined, making them self lubricating and helping to reduce noise.
• Right and Left hand threaded threads, making them super easy to adjust caster.
• CNC'd Adapter washers to perfectly fit the bracket to the chassis.
• Stainless Steel tapered spacers for rod ends to provide greater deflection.
You'll have to see these for yourself, but we're pretty confident that these are the beefiest TC rods ever made these cars! T3 designed these to withstand not just Use by our Road Race customers, but the ABUSE of our Drifting and Rally customers!
These TC rods will provide incredible steering feedback, zero caster deflection and EASY caster adjustment and alignment tuning.
Raptor Racing Beefed up Rear Swaybar Tabs *Free Shipping*
Price:$40
Part Number: Raptor-MK2-Tabs
Notes: In Stock
Another Raptor Racing exclusive, rear swaybar weld-in tabs are perfect for those of you that are sick and tired of breaking your factory tabs. These 1/4" steel tabs are sure to take any abuse you can throw at them and are in easy install for those with welding experience or simply take them to your local muffler shop for a quick install.
Raptor Racing Rear Camber Mod Bracket Kit *Free Shipping*
Price:$104
Part Number: Raptor-MK2-RearCamber
Notes: In Stock
Thanks to members like Carlos Brown and Dave Shephard we are now offering this product. If you're lowring your MK2 at all this product is MUST. Included wih the kit are detailed instructions care of Carlos Bown who graciously provided them to me free of charge.
PLEASE NOTE: The camber bolts are not included with the kit, you will have to source those on your own. Furthermore, these will not work with the factory control arm bushings as the camber bolt is larger, you will need to use the Superpro bushing as they come with the necessary larger sleeve.
Raptor Racing Steering Rack Bushings *FREE SHIPPING
Price: $65
Part Number: RR-MK2-SRBushings
Notes: In stock
Replace your warn out steering rack bushings with a set of Ronnie's MK2 Steering Rack Bushing. This will be the last set of Steering Rack Bushings you'll need.
08-11-2009, 09:45 PM #2
Catalog updated with following:
- All Superpro Bushings now in Stock
- The New Dobinsons are Ready for sale.
- Steering Rack Bushings out of stock...will take a couple months to get more.
10-12-2009, 05:09 AM #3
- Non-adjustable Whitelines discontinued
- Price Increase on AGX Kit due to Supplier Increase
11-07-2009, 11:08 AM #4
Junior Member
- Join Date
- Jul 2009
- Location
- Montreal
- Posts
- 6
I'm intersted in this product :
**NEW PRODUCT** Dobinson MK2 Rear Standard Height Springs *FREE SHIPPING*
Price: $162
Notes: In Stock
Txs
11-09-2009, 12:54 PM #5
Junior Member
- Join Date
- Jul 2009
- Location
- Montreal
- Posts
- 6
Do you have this in stock ?
Price: $162
Notes: In Stock
Txs
11-11-2009, 05:51 AM #6
Sorry Robby for the late reply...yes in stock.
12-19-2009, 04:44 PM #7
UPDATE: Ronnie K Rack Bushings NOW in stock...get them while you can. Unfortunately pricing has gone up slightly since the last shipment.
12-25-2009, 02:10 AM #8
Member
- Join Date
- Nov 2009
- Location
- Houston,tx
- Posts
- 87
pls let me know when u will get some front and rear dobinson standard height in stock, thanks
03-06-2010, 06:59 PM #9
Catalog updated: Dobinson springs for the MK2 are finally in stock with: front lowering; rear standard height; rear lowering and rear 300lb springs.
We use to price them as free shipping but there's HUGE difference in shipping prices from one region to another so now the pricing does not include shipping.
04-11-2010, 08:52 AM #10
Catalog updated...Steering rack bushings out of stock. Expect more stock some time in May.
