Results 1 to 7 of 7
Thread: need some advice
08-12-2009, 04:00 PM #1
Junior Member
- Join Date
- Jan 2009
- Location
- st louis mo
- Posts
- 8
need some advice
i need some advice on taking out a rack and pinion is it really as hard as every one says do i really need the sp tool the in the tsrm will i need a Alignment after
08-12-2009, 11:42 PM #2
the rack and pinion is not hard to remove. Its just two tie rods, two power steering lines, steering wheel shaft and 4 bolts. You will need an alignment after due to any work done to the rack the tie rods need to be replaced/removed.
08-13-2009, 12:54 AM #3
No special tool is needed. Some of the bolts/nuts will be rusted in place so PB Blaster (better than WD-40) or Krol Oil or equivalent is recommended. I also recommend metric flare nut wrenches (line nut wrenches) to use on the lines (good tool to have). $10 at Harbor Freight http://www.harborfreight.com/cpi/cta...emnumber=99993
84P - Primer (faded Lt Blue Metallic) - bought March 5, 1984
83P Auto Daily Driver - Gunmetal Grey - acquired Nov 2007 - Recovered from the dead
82L White - ~44,000 miles Garage Queen
Original Owners List
Under 100K Miles List (starts post 25 - can't update at present)
2012 PNW Supra Events List
82 Vacuum Line Diagram Coloring Book
08-13-2009, 01:02 AM #4
+1 on the flare nut wrenches, you will get very frustrated if you try to use a open ended wrench and just end up rounding out the ends.
-Chris
1983 Celipra GTS:
08-13-2009, 02:34 PM #5
Junior Member
- Join Date
- Jan 2009
- Location
- st louis mo
- Posts
- 8
i have 2 flare nut wrenches a 10mm and something else thanks alot for all the help 1 more ? do i need another person
08-13-2009, 02:36 PM #6
Junior Member
- Join Date
- Jan 2009
- Location
- st louis mo
- Posts
- 8
and how long can i go without a Alignment
08-16-2009, 07:00 PM #7
You shouldn't need help pulling out the RP (I work better by myself anyways).
and for the wheel alignment a.s.a.p. the only reason being is that well your wheel alignment will be out. and therefore the steering dynamics of the car will be comprimised. and there for it will have less stability and predictabilty. you can drive a car with horrible alignment, it's just scarry. spend the $80 to get aligned.
