Results 1 to 10 of 10
    Feb 2009
    Huntsville, AL
    431
    replaced cold start injector and still having problems
    I replaced my cold start injector yesterday and i thought i finally fixed the hard starting problem but today i tried turning my supra on and it still took me 3 or 4 tries. What else can be causing this problem?
    RIP Tad Mattle
    1984 White MKII P-Type, 2jzge, egr delete, 240sx 3" intake pipe with cone filter, CC stage 4 clutch, CC steel light flwheel, ST springs, bilsteins, ss cluth line, DM ss power steering lines, dual contour e fans, 240sx front strut bar, s13 sr20 radiator, Rabidchimp walbro 255, 2.5in super sprint exhaust, poly bushings, t3 camber plates, 3.73 true trac,
  2. #2
    Apr 2007
    Port Orchard,Wa
    2,212
    Cold start time switch or
    Your STA wire is not hooked up. (from the starter to the ECU)
    This tell the cold start to open when the coolant temp is low.
  3. #3
    Feb 2009
    Huntsville, AL
    431
    what does the sta wire look like? pictures would be nice
    RIP Tad Mattle
  4. #4
    Greenville, SC
    11,675
    do you know the CSI is not firing? Test light time.
    --billyM
    Blue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
  5. #5
    Apr 2007
    Port Orchard,Wa
    2,212
    The black wire on a auto or black/white on 5 speeds that is on the CSI and goes to the ECU, Starter after the IGN switch. If the CSI temp sensor is not working it is either grounded (injector always open)or open(injector never opens when cold).
    http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=49
  6. #6
    Oct 2003
    Haddon Twp NJ
    155
    what exactly is the car doing? does it stall at first? If it is warm will the car start right up? I had this problem and did the same thing you did and spent way to much on a cold start injector and realized that didn't fix my problem. Next I did what I found to be called a thermo sensor switch it was located in the thermostat housing. It wasn't easy to find the part but my local auto parts store found it from a company called Airtex they make engine management components they are located in like Iowa any other questions just pm me
    1985 Red
    no mods as of yet need to restore the savings
    Need a turbo
  7. #7
    Jan 2006
    Vancouver, Wa
    1,442
    Your temp switch is the brown plug on thermostat housing. Check this. The green one sits next to it.
    Garrette 85 P-Type
    Stock...Define Stock
    Quote Originally Posted by IDreamOfSupra View Post
    your distributor won't even know you're running boost
  8. #8
    Feb 2009
    Huntsville, AL
    431
    i replaced it and it still has trouble starting up...
    RIP Tad Mattle
  9. #9
    May 2003
    San Diego, CA
    3,828
    You want to look at the EFI temp sensor.
    The larger 2 wire sensor on the thermostat housing is the cold start time switch.
    TSRM Link : http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=72
    The smaller 2 wire sensor, is the EFI temperature sensor. That tells the computer that it is cold outside. Most hard start situations are related to this sensor.
    Chances are the sensor is broken, a common problem. However, many times, it is the harness itself. The wires break right where they bend and enter the connector.
    If you need a replacement sensor and/or harness connector, let me know.
    Just your average MK2 owner...
    84 - 2jzge project
    85 - 6MGTE underway
  10. #10
    Feb 2009
    Huntsville, AL
    431
    yeah i just replaced that sensor. how could i clean the harness connector? I'm also getting pretty bad gas mileage. does this have anything to do with it?
    RIP Tad Mattle
id=a6141150">
