Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
  1. #11
    wow! Good job!
  2. #12
    May 2003
    Ontario Canada
    1,908
    Total respect for your ambition and skill!
  3. #13
    Jan 2010
    Bronx, NY
    502
    AMAZING!! is all I have to say. Serious dedication over there and for it being your first time doing body work you're doing pretty good. Bet you had to do a good deal of research to get this going, body work wise and all, that is.
    Ronni
    84 P-Type With some stuff done to it
    "Guys, what are you going on about?
    ...intermittent attempt to shut off and you're having him check for BHG?"
    --billyM
  4. #14
    Sep 2008
    Calgary
    85
    Thanks guys.
    My favorite saying has always been "Don't wreck them, restore them"...
    I had a teacher in college who told me about a car he worker on a few years before. He said he took two halves of a 2003 Miata and put them together by drilling out all the tack welds along the seams and filling the holes with his Mig welder. This was all i really had for knowledge on panel replacement, I did a little research on welding techniques but that was all. The rest I taught myself. My teacher went a little far though, he even took a punch afterward to the steel and give it the indented tack weld look. I won't be doing that.
    the next update will be what i did to the spare tire well area.
    1985 Supra (Restoration nearly complete)
    2002 Tacoma TRD (multi-purpose)
    1998 Civic SI (daily driver)
  5. #15
    Apr 2008
    Canberra, Australia
    266
    fark dude... totally awesome ill be watching this resto.. keep up the good work
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    JZA61: 1JZ, GT35....That is all
  6. #16
    Sep 2008
    Calgary
    85
    Spare tire well
    Ok, as promised here is some more on my restoration.
    I can't seem to find any good pictures of the spare tire well prior to repair, you'll have to trust me it was not worth keeping. The picture below kind of gives an idea of the rust.
    Originally i had no idea as to how i was going to tackle this repair, but thanks to Junkie who was able to provide this piece at the same time as the 1/4 panels. Unfortunately this floor section was to be scrapped so it was not idealy cut from the car. No biggy, it just meant it would require some additional welding to stitch 3 separate pieces together as seen below.
    The floor was removed to match the piece that was to replace it.
    I drilled out the seam along the back of the car in order to properly insert the floor in between the upper and lower rear fascia.
    This required a lot of test fitting and trimming to match them up
    Preping my frame rails
    And below is what it currently looks like
    Passenger quarter panel replacement to follow.
  7. #17
    Sep 2008
    Calgary
    85
    This one was a mirror image to the drivers side........no joke, but it did go much faster as I was getting efficient by this point.
    Here you can see the rust that had eaten away at my passenger 1/4 panel.
    The rust was so bad that I just had to kick it and it fell right off.....well not quite, but here it is removed.
    bonus rust
    New one mounted
    Next will be upper windsheild corners
  8. #18
    Sep 2008
    Calgary
    85
    Upper windsheild corners
    These corners are a tight radius and i would have found it hard to duplicate so i got new ones off the same silver car.
    On the drivers side it was pretty bad so i ended up replacing most of the front face of teh A-pillar as well as the upper corner.
    upper piece ready to weld
    Ready for filler.
    Passenger side only required the replacement of the corner piece
    Ok onto the next item.
  9. #19
    Sep 2008
    Calgary
    85
    Black powder is great
    Well before i can send the car off to the paint shop i thought i would redo all the suspension components.
    First i replaced the rear sway bar tabs with the thicker one form George.
    Then bundled up some parts to get powder coated
    And there back
    New super-pro bushings from George.
    Now i just need to finish the undercarriage so i can mount these babies.
  10. #20
    Dec 2003
    Raleigh NC
    961
    Just WOW! A very impressive restore project. As someone with no previous experience that just recently went through some (not as extensive) of what you are going through I have nothing but respect for you. You're attention to detail is impressive. Powder coating the undercarriage was a nice touch. I can't wait to see the final product. Keep up the great work.
id=a6141150">
