CT26 Rebuild - How To... by Robert Pina
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    is awesome kmfdmk's Avatar
    Oct 2004
    Vancouver, WA
    2,728
    While looking around I found this walk-through on how to rebuild your CT-26 (assuming you are NOT swapping wheels, and do NOT have a scored center section on the turbine shaft). It was graciously translated by Robert Pina years ago for AllTrac.net
    GREAT Walkthrough. Convinced me to rebuild my own turbo or at least buy the parts to rebuild my original 57 trim that I like better than my current 57 trim. It had a WAY snappier/instant kick you in the ass boost curve. This one is smoother, and if I wanted smooth, I'd get a lexus or something.
    http://www.alltrac.net/tuning/turborebuild.html
    COPIED FROM Alltrac.net
    ps. I have saved these pics and will re-host if necessary and Alltrac.net ever goes down.
    Rebuilding the CT26
    Introduction
    In ordinary situations, the owner of a car does not rebuild his own turbo. However some have noticed that just a short time after having their CT26 rebuilt or upgraded, the seals have blown and oil is leaking. It is not necessary to do a full rebuild in this case, so a simple seal replacement is in order. Doing this step is easier than you might think. A complete rebuild can be done in some situations however, a really bad turbo must be upgraded by a professional. With this in mind, here is somewhat of a guide for you when attempting this procedure.
    Before we begin, take a second to familiarize yourself with CT26 and it's parts. There are 3 main parts:
    • Compressor Housing
    • CHRA (Center Housing, Rotating Assembly)
    • Exhaust Housing
    Compressor Housing
    While the first and last are obvious, the CHRA is basically everything inside. From the compressor wheel, to the turbine on the exhaust side,
    and the bearings seals and actual center section. The bearings in the CT26 are of a floating type. Which means they "float" in a coat of
    oil. That's why with this turbo, it's very important to always run clean oil and follow proper cool down procedures.
    Here's a layout of the supra CT26 (courtesy CJsupra). If you were to buy a CHRA (pictured) it comes rebuilt and assembled. The exhaust, compressor
    housings have been ceramic coated, as well as the turbo elbow. There is a bag of new bolts from Toyota (recommended), and in the bottom right is
    the clamp that holds the CHRA to the exhaust housing.
    Journey into the unknown...
    One thing to keep in mind is that the turbocharger requires a precision balance since it spins in excess of 100,00 RPM. If you do something to upset this balance, you can have a new hole in your turbo where the compressor used to be. Please be careful. Please do not hold us responsible. For the most part replacing just the seals is no problem. Attempting to repair a turbo with excessive play is very hard to do properly.
    Disassembly
    1. Remove Turbo Clamp covering center section (2x12mm Bolts)
    2. Heat the connection between center section and exhaust housing (Hair dryer)
    3. Knock exhaust housing free using mallot, or drive a piece of wood in between to wedge the pieces apart (Bigger Hammer sometimes required)
    4. Examine exhaust housing for cracks, replace if necessary
    5. Use some large needle nose pliers or something similar to undo the large C-clip holding on the compressor housing
    6. Remove the compressor housing seal using a small pick
    7. Mark the position of the compressor wheel to the mounting nut and turbo shaft. Must be re-installed in the same position.
    8. Place turbine side in workbench vice upright, remove turbo nut. (10mm if previously rebuilt, otherwise SST for toyota nut, or vice grips)
    9. Remove compressor
    10. Needle nose pliers again to remove small C-clip
    11. Remove top bearing (may require vice grips to pull up)
    12. Remove inner oil seal
    13. Remove washer
    14. Remove Bearing
    15. Remove Center Section from Turbine
    16. Clean and examine Turbine
    17. If the inside of the center section is scored, it must be re-bored by professional
    18. Assemble in reverse order, coat parts with fresh oil
    19. If you removed Toyota compressor nut, replace with new.
    Parts Source
    USA:
    ADP @ 1800-225-3596...ask for Darell
    $107.75
    Canada:
    Bramall Turbo Supply Ltd.
    bramall@bramall-turbo.com
    119 Spy Court
    Markham,Ontario
    Canada. L3R 5H6
    Toll Free: 1 (800) 567-7559
    Phone: (905) 477-7559 Fax: (905) 470-0618
    CT26 Repair Kit PN# CT2003
    It's me Rusty now.
    That being said...
    I would scribe the compressor nut with a razor knife or a VERY FINE tip Sharpie.
    I did some reading and on SupraMania they said to use as big a hammer as you feel comfortable (more or less you have to beat the ever living shit out of the exhaust housing to get it off).
    Also I would use a heat gun, not a fucking hairdryer on the exhaust housing. Really!!? a blow dryer?
    I am ordering a rebuild kit tonight (From Driftmotion.com, who has a custom billet seal plate), and overnighting it to me here in Louisville. Expect a rebuild thread with pictures AND video in the coming weeks.
    Peace.
  3. #2
    CelicaSupra.com Member Wolfgang's Avatar
    Sep 2004
    Vancouver BC
    552
    Dude, thanks for the post. Not many people have the courage to undergo something like this.. Good luck!
    85 Supra, Red, Auto, 300k. Chimpy 6M. MHG & ARPs. 60-1 Trim, Stainless Lines, Q45 Brakes, 16's, Al Rad+E fan, Oil kit and cooler, MSD 6a + Accel Coil ms2 3.57... Air shocks and coil overs in the works.. Maybe a mk3 trans next........
  4. #3
    Sep 2004
    Vancouver BC
    552
    Oh, and was kmfdm killer mother fucking dance mix, or was it ketchup made from dead mice...
    Onoo I remember now.. Karl Marx found dead masturbating.
    On that note Im going to look for my symbols CD..
  6. #4
    Oct 2004
    Vancouver, WA
    2,728
    Thanks man.
    CT26 Spec's per MKIII TSRM
    NO MORE THAN:
    0.13mm Axial Play (in/out/front/back) - 0.0051"
    0.18mm Radial Play (side to side) - 0.0071"
    If more play than listed, a rebuild is necessary (according to the TSRM).
    These are the pieces normally found in a CT-26 Rebuild Kit:
    Here is an exploded diagram of the CT-:
  7. #5
    CelicaSupra.com Member Dakar2008's Avatar
    Jan 2006
    chicago, illinois
    657
    one thing too before anyone orders a rebuild kit. check which type of seal your ct26 has, carbon or dynamic,
    5M-GTE 86 5sp cressida certified used toyota edition
    Hidden Content
    Hidden Content
  8. #6
    Oct 2004
    Vancouver, WA
    2,728
    Quote Originally Posted by Dakar2008 View Post
    I have no idea.... I believe they have Dynamic... or at least the seller on ebay, recommended by SM people has a Dynamic Seal listed as included...
    ebay seller : turbos_r_us
  9. #7
    CelicaSupra.com Member SupraLee's Avatar
    Mar 2006
    Colorado
    824
    nice, this is interesting...
    1984 Supra, 7MGTE,3",Magnaflow,Sparco 383,Sparco Corsa,AGX,Koni,Addco,TSC bar,LJM,GC Coilovers, Eibach,T3 Camber, T3 RCA, T3 Steering Arms, Dobinsons, SuperPro,Rear Camber Mod,PST,16x8 Circle Racing,Cressida Lip,JK BBK,PG Power Brute LSD,Black interior,Griffin Radiator
    Hidden Content
  10. #8
    Apr 2003
    San Diego, CA
    1,051
    FWIW, I did not "do" the original write up. I found this write up, on a site in Japan, in ~2002. I translated the text and re-hosted the pictures back then.
    That said, I'm glad that the information is being put to use, and being updated to what is available today.
    I think many people don't realize it's pretty easy to take apart a turbo. I recently replaced a chipped compressor wheel on a CT26 with a good one and everything works great.
    There is actually a good video of a CT26 rebuild, that was attached to this original page. It was an MR2, but it was interesting to see the turbo being taken apart, upgraded, and balanced by the shop. If I can find it, I will add it to this post.
    I would take the name out of the write up, since I was not the original author of the write up.
    85 Supra 7MGE Lightweight
  11. #9
    CelicaSupra.com Member bozosoku's Avatar
    Jul 2003
    Charlotte, NC
    511
    I rebuilt a couple of CT-26 with this very helpful article as reference a few years ago, the hardest part is to seperate the exhaust housing and center section, it took some good poundings with a copper head hammer before they came apart, make sure to clamp the center section down with a good solid vise, the rest is straight forward. If the old turbo already has excessive radial play, just replacing the bearings with the kit may not bring it back to spec. Chances are the bore in the center section needs to be reamed and use an oversized piston ring on the hot side, supermania has a good sticky in the turbo section on how to do this.
    84 L type, 7MGTE
  12. #10
    CelicaSupra.com Member pat2330b's Avatar
    Oct 2007
    Montreal, Canada
    267
    Nice post!, this is good information for turbo rebuilt.
    thx
