For sale: 7MGTE engine swap package
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    CelicaSupra.com Member supraholic's Avatar
    Jan 2009
    New Hampshire, USA
    201
    Here's your chance to pickup a great running 7MGTE motor that is ready to drop into your MKII. Many new parts with the top end under 200 miles old and bottom end around 30k miles old! I bought this car from a fellow cs.com member last year (http://forums.celicasupra.com/showthread.php?t=39746) which lists all the engine specs at that time of the sale. I've put less than 1,000 miles on the car since I bought it before I started a 2JZ swap. Here are some details and specs:
    * 1988 7MGTE Engine; ran stock boost
    * 1988 MK3 7MGTE ECU (stock) included
    * Engine wire harness (plus ignitor, resistor pack, etc.) included
    * I have a spare 7MGTE engine harness I'll throw in too! (missing 2 plugs)
    * 7M transmission bell housing included for your w58 trans
    * 31K miles old: Rebuilt bottom end all new OEM Toyota lower end bearings new OEM Toyota rings.
    * Re-manufactured Head from Clearwater Cylinder heads with new HKS 1.2mm Metal Head gasket and ARP studs/fasteners. Under 200 miles driven with this new head! (The old head had a burnt valve but I just swapped the entire head)
    * New Toyota seals, gaskets for engine assembly
    * 31K miles old: OEM Toyota oil pump with 5mge pick up tube
    * 31K miles old: OEM Toyota 7MGE clutch, pressure plate and T/O bearing
    * 31K miles old: OEM Toyota Clutch fan for radiator
    * Under 200 miles old: OEM Toyota Water pump
    * Under 200 miles old: Autolite copper spark plugs
    * Under 200 miles old: Bosch bypass valve
    * Brand new 7M OEM Toyota fuel filter
    * Includes Stock MK3 Front Mount Intercooler and all piping
    * Oil Filter relocation kit (one of the hose fittings leaks)
    * Oil cooler from MK3
    * K&N cone filter for stock AFM
    * Turbo is in great shape, zero shaft play, run only on stock boost
    * Engine runs great; no smoke, no leaks--everything runs tip top!
    * Engine mounts already on the motor so it's ready to drop into your MKII!
    All this engine needs is a fan blade, heater hose for the back of the head as I used for my 2J swap, and the AC compressor wheel squeaks so the bearings might be shot . The clutch was slipping before I pulled the motor so you will need a new clutch and resurfaced (or new) flywheel before bolting up your trans.
    I REALLY prefer local pickup so hopefully someone in the North East is looking for a GREAT 7M swap package that is ready to go! I wanted to give the CS.com community a chance to buy first as I'll be posting to Craigslist in a couple weeks. Need to move this out of my garage so I'm willing to let it all go for $1500. Pickup only. If I get no takers here or on Craigslist after a few weeks, I may consider shipping. Here are some pics:
    Make your 4th of July holiday a bang with this 7M! Shoot me a PM if you'd like any additional pics or information.
    -Dan
  3. #2
    CelicaSupra.com Member discoelk's Avatar
    Apr 2005
    Georgia
    3,969
    Is this a plug in play harness? Why the hell does all this stuff pop up after I drop money on a rebuild....
    David H
    85 P, LS6/R154/3.58/TrueTrac etc
  4. #3
    Jan 2009
    New Hampshire, USA
    201
    The engine harness has the OEM MKIII plugs so you would need to source the female ends to mate up in the dash to make it 'plug and play'...
  5. #4
    Apr 2005
    Georgia
    3,969
    Good to know. Still an awesome deal IMO.
    David H
  6. #5
    CelicaSupra.com Member zuprax85's Avatar
    Aug 2008
    baltimore
    3,223
    Quote Originally Posted by discoelk View Post
    agree!!!
    Edgar M.
    85 Two tones P-type 5 speed R.I.P Hidden Content
    84 White P-type 2JZ-GE 5 speed Hidden Content
    Hidden Content
  7. #6
    CelicaSupra.com Member Superium's Avatar
    Nov 2003
    Buffalo, NY
    2,248
    Good deal but what the hell's up with everyone installing their bosch bpv's on backwards? Thats 2 in the last week I noticed.
    Mark K. -'83 Supra (Carmen) -'87T Supra (Cailin) -'91 Accord (wtf)
    Hidden Content
  8. #7
    CelicaSupra.com Member Citskipper's Avatar
    Jan 2010
    Swannanoa, NC
    519
    If I was closer and had a way to get it from your place to mine (ie anything but a supra) I would be all over it!! sad I cant get it :-(
    '85 Supra - Homemade carbon-fiber headlight covers, homemade twin 10" sub enclosure in place of back seats, lots of blue under the hood, Rabid Chimp 2.5" exhaust mated to a custom muffler, 16's, lowered front end, T3 camber plates....7M-GE(T) on the stand, in progress!! Hidden Content
    Never ending project Hidden Content
  9. #8
    Junior Member Oleanderbliss's Avatar
    May 2008
    New Jersey
    13
    Hey man ill buy i it n ill be able to pick it up just let me kno.
  10. #9
    Jan 2009
    New Hampshire, USA
    201
    Oleanderbliss--got your PM and responded...
  11. #10
    CelicaSupra.com Member ihateu3's Avatar
    Feb 2010
    ashland ohio
    1,401
    did this sell? Please update!
    This message will self destruct
