For sale: 7MGTE engine swap package
26K views 30 replies 16 participants last post by  Whitey482
#1 ·
Here's your chance to pickup a great running 7MGTE motor that is ready to drop into your MKII. Many new parts with the top end under 200 miles old and bottom end around 30k miles old! I bought this car from a fellow cs.com member last year (http://forums.celicasupra.com/showthread.php?t=39746) which lists all the engine specs at that time of the sale. I've put less than 1,000 miles on the car since I bought it before I started a 2JZ swap. Here are some details and specs:
* 1988 7MGTE Engine; ran stock boost
* 1988 MK3 7MGTE ECU (stock) included
* Engine wire harness (plus ignitor, resistor pack, etc.) included
* I have a spare 7MGTE engine harness I'll throw in too! (missing 2 plugs)
* 7M transmission bell housing included for your w58 trans
* 31K miles old: Rebuilt bottom end – all new OEM Toyota lower end bearings – new OEM Toyota rings.
* Re-manufactured Head from Clearwater Cylinder heads with new HKS 1.2mm Metal Head gasket and ARP studs/fasteners. Under 200 miles driven with this new head! (The old head had a burnt valve but I just swapped the entire head)
* New Toyota seals, gaskets for engine assembly
* 31K miles old: OEM Toyota oil pump with 5mge pick up tube
* 31K miles old: OEM Toyota 7MGE clutch, pressure plate and T/O bearing
* 31K miles old: OEM Toyota Clutch fan for radiator
* Under 200 miles old: OEM Toyota Water pump
* Under 200 miles old: Autolite copper spark plugs
* Under 200 miles old: Bosch bypass valve
* Brand new 7M OEM Toyota fuel filter
* Includes Stock MK3 Front Mount Intercooler and all piping
* Oil Filter relocation kit (one of the hose fittings leaks)
* Oil cooler from MK3
* K&N cone filter for stock AFM
* Turbo is in great shape, zero shaft play, run only on stock boost
* Engine runs great; no smoke, no leaks--everything runs tip top!
* Engine mounts already on the motor so it's ready to drop into your MKII!
All this engine needs is a fan blade, heater hose for the back of the head as I used for my 2J swap, and the AC compressor wheel squeaks so the bearings might be shot . The clutch was slipping before I pulled the motor so you will need a new clutch and resurfaced (or new) flywheel before bolting up your trans.
I REALLY prefer local pickup so hopefully someone in the North East is looking for a GREAT 7M swap package that is ready to go! I wanted to give the CS.com community a chance to buy first as I'll be posting to Craigslist in a couple weeks. Need to move this out of my garage so I'm willing to let it all go for $1500. Pickup only. If I get no takers here or on Craigslist after a few weeks, I may consider shipping. Here are some pics:
Make your 4th of July :salute: holiday a bang with this 7M! Shoot me a PM if you'd like any additional pics or information.
-Dan
#7 ·
If I was closer and had a way to get it from your place to mine (ie anything but a supra) I would be all over it!! sad I cant get it :-(
#15 ·
your right, I have read this thread prolly about 15 times, and just got caught up with my over eagerness, totally forgot that the harness already was discussed, but the shipping? Said prefer a pickup but if it didn't sell right away would consider shipping. Crossed fingers here.
#18 ·
If I buy this 7m, then I will sell you my 5mge cheaper than you could rebuild it. $200, runs great and I'm only one state away, I also have another 5mge right now that has low oil pressure issues (no rod knocks though) that need figured out, $100 and its yours. Sorry, not hijacking this thread, just giving silverspoon a little guidance!
#25 ·
Yes it's backwards.
#26 ·
Hey Dan , Im really wowed on how great this engine looks. I have an MK!! as my daily and i want to swap my 5M to a 7MGTE soon ....like in 1 month, i saw that u were considering shipping after a while. I live in California and I was thinking if no one gets it in about a week ...we could negotiate.. Please feel free to hit me up. im really interested....
#29 ·
WTF! What makes you think this is a current forsale thread? You revived a dead thread, this is an old thread, this was bought by a noob a couple years back and he has since sold it again in another forsale thread. BTW, he was a noob but he's since become one of the better contributors around here.
