Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Aug 2005
    lebanon ky.
    40
    Last 2 oil filters not working correctly. 206,000 miles on engine 1982 Supra
    The last 2 engine oil and filter changes have me puzzled. 2 oil changes ago when I removed the Fram ph3614 filter there had never been any oil that had gone through it judging by the weight of the filter. When I unscrewed the filter no oil ran out of it and it looked like it was still new. After replacing the filter with another new Fram ph 3614 and after 6000 more miles I changed my oil and filter yesterday. This time the Fram filter was a lot heaver and it must have been filtering the oil for a while. Still no oil ran out of the filter when I removed it. Yesterday I replaced the oil filter with a Wix 51068 at the suggestion of an Oreilly auto parts clerk.
    Do you think there is something stopped up regarding my oil filter? My oil pressure seems to be good enough judgeing from the reading of my oil pressure gauge. The oil pressure is not as high as when the car was new but the hand on the gauge goes over half way up when driving on the highway.
  2. #2
    Spring Hill, Fl.
    13,999
    fram filters suck. the oil drain back valve doesn't work so the oil drains back into the block. i use a purolator. the reg white one. and use one for a 5.0 mustang. its larger and screws right on. its a 30001 i believe. theres no way for oil to get to the main galley without going through the filter first btw. if you really want more filterint use the premium plus filter, though the reg white one has way more sq/in of filter area then the stock mk2 oil filter already.
    william
  3. #3
    Jun 2006
    british columbia canada
    448
    the way the filter is mounted it should drain out
    1984 celica supra with 7mgte swap, custom intercooler, lexus v-8 airflow meter,mk3 fuel pump, 3.5 downpipe with 3 inch exhaust, race muffler, adjustable boost controller, 60 trim ct 26, with r154 tranny, 16x8 xxr s13's with 245/50R16 bfg g force sport, 13.6 @ 105
  4. #4
    Spring Hill, Fl.
    13,999
    thats what the anti drainback valve is for. to prevent this from happening, the frams have cardboard endcaps and they leak back into the engine past them.
    william
  5. #5
    Jan 2008
    katy, tx
    780
    Get the oil relocation kit. Not only do you not have to worry about the oil draining back out but you dont have to deal with the b.s. when trying to take the filter off in the first place.
    I think I was pretty curious as to why toyota made the oil filter upside down to begin with the first time I did an oil change.
    if all else fails, use a hammer
  6. #6
    Nov 2004
    Graham, WA
    5,104
    Stay the hell sway from fram!!!
    -Chris
    1983 Celipra GTS:
  7. #7
    Spring Hill, Fl.
    13,999
  8. #8
    Jun 2010
    Rapid City SD (99%); Eagan, MN(1%)
    180
    Quote Originally Posted by 83CelWA View Post
    Yeah, Toyota filters FTW.
    http://www.celicasupra.com/forums/sh...277#post593277
    Reasons: it's heavier duty, more threads, thicker walls. It's like the titanic of oil filters for our cars. Also, as was said in that linked thread, it's designed for the toyota engine, not a resized one design fits all like fram.
    1984 P-Type, daily driver 82k GR2 EXCEL-G front & Gas-A-Just rear
  9. #9
    Jan 2008
    katy, tx
    780
    That is odd that you all complain about the FRAM. I have used nothing but the only problem I have is the back flow that William was talking about.
  10. #10
    Spring Hill, Fl.
    13,999
    the back flow is the biggest problem. means starting the engine with the oil system "dry". not a good idea.
    william
id=a6141150">
