Results 1 to 8 of 8
    Jun 2006
    Barrie, Ontario
    145
    Oil Pressure Gauge Norm
    Hey, not sure if it's just me but, while driving I get the pointer to the middle line on the oil presssure gage, at idle that will drop to the 1/4 position. Makes me worry. tried two different sending units.
    Where does yours normally read?
  2. #2
    Jan 2008
    katy, tx
    780
    Yes this is normal. At idle your crank is not turning as many RPMs as when you are driving so your oil pump will not be pumping as much pressure. So your reading is supposed to fluctuate. I got rid of the idiot gauge and put in an after-market one to see the numbers.
    Start up idle: 40lbs (+/-)
    Idle (normal running temp) @ 1000 RPMs: 20lbs
    3000 RPMs (NRT): 45-50lbs
    Depending on what your idle screw is set at, you can actually watch you oil gauge rise and fall with out driving. 1/4 point at idle sounds about right (if your idle RPM is between 850 - 1000 RPMs)
    Those idiot gauges suck. You can get after market one for $25-40 if you just want to check everything to make sure that you have good pressure. Alot of them are electric. It comes with a sensor that you screw in to replace the OEM oil pressure sender which you connect a wire to that leads to the gauge. Install time takes all of 15 minutes.
    if all else fails, use a hammer
  3. #3
    Dec 2009
    westminster, md
    377
    i put oil pressure gauges on my first two mk1s and they both read the same as above. it seemed a little worrysome to me that oil pressure seemed so low, but neitehr car had issues and teh engione from one is still going strong in anotehr mk1. so i figured it was normal.
    '85 merkur xr4ti (too many mods to list)
    '05 toyota taco
    '79 celica supra
  4. #4
    Apr 2006
    Mid-Western Ontario.
    1,058
    Hey Rick, you must have got the motor in! Is this the 5MGE?
    '80 Celica Supra 5 spd Metalic Red
    '97 Mazda MPV 4x4 Blue/grey
    '98 Toyota Rav4 Silver
    '09 Honda Ridgeline Sterling Grey Metalic
    * Good judgment comes from experience, and a
    lotta that comes from bad judgment.
    * Lettin' the cat outta the bag is a whole lot
    easier than puttin' it back in.
  5. #5
    Jun 2006
    Barrie, Ontario
    145
    Yup, up and running. Today I'm installing exhaust system.
    I'll have to come by for a visit.......if your up to a test drive.
    Check out the vids on the MKI forum.
  6. #6
    Apr 2006
    1,058
    Hey, I am off until Friday morning. Give me a call, I also here FOX is hiring quite a few guys right now.
  7. #7
    Oct 2011
    westtown ny
    10
    glad i found this. I just got my supra yesterday and noticed that the oil pressure gauge was offly low. So i hit the throttle and it went to about the halfway point. I was a little scared so i shut it off and wasnt gonna run it again until i could get a pressure gauge on it.
  8. #8
    Oct 2011
    westtown ny
    10
    I looked up the factory oil specs from toyota on alldata and they said at idle it should be more than 4.3 psi and at 3000 rpms it should be 36-71 psi. Which is kind of a broad specification but thats what they say it should be at.
id=a6141150">
