Quick Help, testing oil pressure sending unit?
Results 1 to 10 of 10
    CelicaSupra.com Member 84ptype's Avatar
    Nov 2006
    Spokane, WA
    7,930
    How do I test this? nothing in the TSRM or repair manual. Dont want to just assume the sending unit is bad and keep running the car..
    swapped 2 gauge clusters and neither worked.
    Scott~~~85SDR5mgte Hidden Content
    Hidden Content
    Sponsord by DIYautotune.com
    Hidden Content
    Hidden Content
  3. #2
    CelicaSupra.com Member afronippleyo's Avatar
    Nov 2009
    Modesto, CA
    622
    I think I remember seeing something about a recall on that. might be wrong but worth looking into.
    Nick R. Goss.
    83 Supra P-Type Bone Stock Beater (goneHidden Content )
  4. #3
    CelicaSupra.com Member zuprax85's Avatar
    Aug 2008
    baltimore
    3,223
    maybe is just bad, if is not the gauges, could be wiring or the sending unit itself.
    Edgar M.
    85 Two tones P-type 5 speed R.I.P Hidden Content
    84 White P-type 2JZ-GE 5 speed Hidden Content
    Hidden Content
  6. #4
    Nov 2006
    Spokane, WA
    7,930
    Yeah, Im trying to narrow it down so I dont blow 50 on a sending unit when thats not the problem...
    Hidden Content
    Hidden Content
    Hidden Content
  7. #5
    Aug 2008
    baltimore
    3,223
    for $50 u can get a nice aftermarket oil pressure gauge w/ sending unit, grab a used one at your local junkyard for free, just put it in your pocket lol
    Edgar M.
    Hidden Content
  8. #6
    Nov 2009
    Modesto, CA
    622
    Quote Originally Posted by zuprax85 View Post
    ^^^I 2nd that. its called pick'n'pocket for a reason. haha
    Nick R. Goss.
  9. #7
    Aug 2008
    baltimore
    3,223
    Quote Originally Posted by afronippleyo View Post
    LMAO
    Edgar M.
    Hidden Content
  10. #8
    Nov 2006
    Spokane, WA
    7,930
    Its in the wiring somewhere...2 gauge clusters and 2 sending units (one out of my 85 that is known working).
    Im not gonna chase the wiring...aftermarket gauges it is!
    Hidden Content
    Hidden Content
    Hidden Content
  11. #9
    CelicaSupra.com Member ABUSEDDOG's Avatar
    Oct 2006
    edmonton. alberta
    732
    Might be a longshot.....perhaps stick a voltmeter on the the end of the sending units and rev. The voltage signal should change....???
    Voltage changes, Im assuming sender is OK. Probably indicates bad wiring or cluster.
    fav car pics
    Hidden Content
  12. #10
    Nov 2006
    Spokane, WA
    7,930
    The pressure sending unit is actually the ground side of the circuit.
    12v pos. on the back of the cluster, ground circuit ran to cluster from sender. More pressure= less resistance, makes the gauge go up.
    Hidden Content
    Hidden Content
    Hidden Content
