All Motor 5MGE Build List
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    CelicaSupra.com Member
    Aug 2011
    Tampa, FL
    144
    I've finally decided to forget about the 5M/6M/7MGTE build and stick to what I know best.
    This is not only a hell of a lot cheaper than my previous project plan, but about as easy as it gets too.
    Here is the build list so far.
    - Rabidchimp -
    ARP Head Stud Kit
    ARP Main Stud Kit
    Ceramic Coated Cold Air Intake
    OEM Clutch Master Cylinder
    OEM Clutch Slave Cylinder
    OEM Full Gasket Set
    HKS 1.2mm Head Gasket (84mm)
    KYB AGX Shocks and Struts
    LM1 Wideband A/F Ratio Meter
    OEM Oil Pump
    +1mm Valves
    OEM Rocker Arms
    Ross Racing Pistons (84mm, 10.5-11CR)
    Complete Super Pro Bushings
    OEM Valve Stem Seals
    Walbro Pump
    - Horsepowerfreaks -
    ACT HDR6 Clutch Kit
    Crower Steel Connecting Rods
    Ferrea Aluminum Magnesium Retainers
    Jaws Steel Driveshaft
    Jun Cam Gears
    Kaaz 2-Way LSD
    Toyota Axles for Kaaz LSD
    Magnecor 10mm Plug Wires
    NGK Iridium Plugs
    Porterfield R4S Brake Pads
    Rotora Drilled and Slotted Rotors
    Suspension Tech 1.3'' Lowering Springs
    Techna Fit Steel Brake Lines
    Techna Fit Steel Clutch Line
    OEM Shift Lever Bushing
    OEM Shifter Seat
    OEM Shifter Gasket
    OEM Shifter Boot
    Whiteline Front and Rear Sway Bars
    - Andysautosport -
    Crane PS40 Ignition Coil
    Blackworks Red Battery Tie Down
    Gude Performance Head Package (Reground Cams, Ported Intake Manifold and Throttle Body, +1mm Valve Ports, Gude Performance ECU, Race Ported and Polished Head)
    Flowmaster 40 Series (3.5''entry/3.5''exit)
    NRG Red Radiator Cap
    Ichiba 25mm Wheel Spacers
    Energy Suspension End Links
    Blitz Oil Cap
    - Autopartswarehouse -
    OEM Motor and Transmission Mounts
    Comp Cams Assembly Lube
    Gates Timing Belt
    OEM Wheel Bearings
    Mr Gasket Heat Insulator
    Taylor Exhaust Wrap
    Bosch Distributor Cap
    Bosch Distributor Rotor
    Bosch Starter
    Bosch Alternator
    Russell Red Fuel Line
    OEM Injectors
    OEM Coolant Temp Sensor
    Beck Arnley 160 degree Thermostat
    Gates Radiator Hoses
    Bosch Water Pump
    Performance Radiator 2 Row Radiator
    - Ebay -
    OBX Headers
    W58 Rebuild Kit
    - Custom Fab Work -
    Full Cage
    Strut Tower Bars
    Steel Plates for Motor Mounts
    3.5'' Aluminum Exhaust from the Header --->
    Anyone have any clue as to what kind of WHP/WT I will see? I'm not familiar with how Toyota straight 6 engines react to all motor builds, but I'm sure it would be a fun car.
    Thanks for any responses.
  3. #2
    CelicaSupra.com Member Dakar2008's Avatar
    Jan 2006
    chicago, illinois
    657
    i can get arp rod bolts if you're interested. http://www.celicasupra.com/forums/sh...-ARP-rod-bolts,
    5M-GTE 86 5sp cressida certified used toyota edition
    Hidden Content
    Hidden Content
  4. #3
    Member
    Jul 2006
    Kootenays
    79
    How about a set of extreme cams from Paeco.com. FYI Ross pistons are nearly the heaviest piston set you can get (not very helpful for high rpm). Crower rods? I though those were inappropriately priced. I see little advantage over cheap eagle rods (I'm actually not even sure if these are available). If your not planning to do some kind of itb set up then how about a forward facing intake manifold modification with a larger throttle body? And of course all the fancy electronics to run it.
    (Following paragraph about 7MGE)
    Really you should save up some money and just but a stage 2 Paeco 7MGE for $6800 and be happy with the 293 advertised horsepowers. Bolts right onto your tranny and into your motor mounts. Get a new TOGA high flow oil pump for a 5MGE and bolt it onto your 7M block with the 5M pan and your set. Also an ATI Damper from Summit for $350 probably a good idea. While your at it grab a CSR Water Pump and save 7 horse and improve you cooling. http://www.autoenginelube.com/ those guys sell a well priced engine oil pre lubber kit that should be OEM on every car period.
    ACT Cluches suck.
    http://www.celicasupra.com/forums/sh...oducts-Catalog
    Raptor Racing Feramic Clutch is the one to have.
    Get a set of 48DCO's Ill make you a manifold to mount them. I'd use Brian Crower Retainers Titanium and well priced. Ferrea is some kind of auto fashion bull. Chevy Big Block inner springs are required for crazy cams. Those Kaaz diffs are pricy? I like the True-Trac.
  6. #4
    CelicaSupra.com Member Don L.'s Avatar
    Fremont, Ca.
    1,809
    Wow, you have an impressive list of parts! You will get a bunch of responses from members with suggestions of much cheaper ways to get much more hp. Don't take it personal, I went that route too, kinda. Building a 5mge rather than the other choices always raises eyebrows. I would guess if you assembled the motor as listed, you might get 175whp, maybe 165 ft/lbs torque. It's not always the sum of the parts, but also how well they work together. My 5mge was bored .040 over, shaved head, some head work, blueprinted cams (mostly stock), 3" exhaust, custom header, 3 ITB setup, SDS standalone, cam gears. I believed I maxed at about 178hp, 186 ft/lbs. Maybe a bit more later with tuning, but not much more. You will have a fun project car, with all the other upgrades too, but it won't make 200hp. What I would do if you wanted to stay with the 5mge n/a route: get a standalone so you can tune (really essential, otherwise your stuff is wasted), larger injectors, probably 250cc units, lighten the crank/rods/pistons as much as possible. You will need to make your power with revs, shoot for 8000rpm or more. Think about the intake system too. If you go ITBs and standalone, get rid of the air flow meter, will let your cams breath better. I should be selling my ITB kit, and SDS standalone in a month or two. Check it out later.
    Bottom line though, its your money, spend it how you want. Yes, the True-trac is probably a much better choice for the street than the Kaaz. I have both. Kaaz is a 2-way, I really need a 1.5 way unit but Kaaz doesn't come that way. I working on a solution.
    Good luck on the project, it sounds like a fun build.
    Don L.
  7. #5
    Aug 2011
    Tampa, FL
    144
    @ Dakar2008
    Nice. I think the Crower rods come with those bolts but I'll keep it in mind.
    @DexterRogers
    I'm not entirely sure I want to lighten up the rotating assembly. I'm more interested in torque than horsepower, so the more usable weight I can get on the crank, rods, and pistons the better. I may knifeedge the crank, but that's about it. I don't think Eagle makes rods for the 5M. I would love to do an ITB setup but I shiver in fear at the thought of doing wiring or any tedious electronic work. Does the 7M intake manifold bolt up to the 5M head?
    @Don L
    The Gude ECU has an available a piggyback programmer to run bigger injectors if I need, but I can't find any larger direct fit injectors. How much of a difference does an ITB setup make on the 5M? Again, with the weight reduction of the rotating assembly, won't I lose torque do to loss of rotating mass?
    I don't expect 200whp, but I would love to make 200 ft.lbs at the wheels.
  8. #6
    CelicaSupra.com Member CarFreek's Avatar
    Auburn, WA.
    6,023
    Quote Originally Posted by jdmfreak92 View Post
    You will need more ccs. One quick recommendation-you had better get on the phone and check real world availability on your parts list. At least 1/2 the parts you listed no longer exist, or the vendor doesnt ship em anymore.. In my opinion, the gude package is a huge waste of coin. You dont need a piggyback if going standalone, eh? Its your dinero..
    86 SDR-"Shuttlecraft" 16" Drag dr-27 wheels, Coilover/AGX/Celica Arms front, Camber Mod/Cut Springs rear, Poly Bushings all around, Whiteline sway bars, 13" bbk front, and 12" bbk rear, Weir Diff bushing, Pacesetter with custom RABID CHIMP mandrel bent 2.5 with Flowmaster resonator, short shifter, 5m-GZE using upgraded sc-14 Toyota supercharger, with Custom RABID CHIMP piping..
  9. #7
    Member
    Jul 2006
    Kootenays
    79
    http://www.youtube.com/watch?v=73pQW..._order&list=UL
    Jens sweet itb set up.
    I think the formula for all motor builds is somewhat universal for piston engines. You want the maximum displacement and the lightest possible internals to raise the redline- all to promote more airflow. When I think of Ross pistons I think of a 350 gram weight pulling at like 4gs on the con rods (opposed to 290g CP pistons (educated numbers pulled from my ass)). A heavier set of internals will probably have better inertia and be more street able but if thats what you want then leave the stock flywheel but lighten the engine internals.
    IMHO a CelicaSupra with over 200 wheel horse and torques (like Jens ITB 7M) is fun a plenty. A light sports car is like 3000lbs. Seems heavy but only the super light weight cars like lotus are much lighter than that. In my world I don't do that much racing, its the roads and experience im after. nothing like metering out power, transitioning from cornering, squeezing the throttle and holding that last .1 or .2 G's worth of grip... NA engines are required for smooth fast corners in my books.
  10. #8
    CelicaSupra.com Member BillyM's Avatar
    Charlotte, NC
    12,790
    You want 200rwtq? Well, you could spend $5,000 on all that engine crap you've listed there...
    ...or...
    "Hello, nice to meet you."
    Use the right tool for the job.
    -billyM
    White 85P - Blue/Silver 85P
    Hidden Content
    Hidden Content
  11. #9
    Member
    Jul 2006
    Kootenays
    79
    I agree with billyM ^^
  12. #10
    Spring Hill, Fl.
    14,651
    honestly, easiest n/a setup would be a 2jzge. they are dirt cheap. custom mounts to make them fit readily available. 240hp stock. port and polish the head, some itb's, header, exhaust, megasquirt setup, and tune. you can run a w58, r154 with a stock bell housing and flywheel no prob.
    or just run header, exhaust, intake pipe and filter with stock ecu and prolly never have any reliability issues ever.
    the 1uz would be nice, but not as easy. you need a custom drive shaft and custom adapter to fit a 5 speed, custom flywheel, custom headers, etc... the 2jzge would be cheaper overall, though not quite as much tq, but would be a huge improvement over the 5m. easily 100+rwhp over a stock 5m with some breathing mods.
    william
    Hidden Content blue 85 beater
