Results 1 to 7 of 7
Thread: B-Pillar
02-23-2012, 11:43 AM #1
Member
- Join Date
- Mar 2011
- Location
- richmond virginia
- Posts
- 31
B-Pillar
Anyone need a set of MK1 Pillars picked them up from the junk yard very good condition. Only one has two spots of minor sun damage. will post pics soon.
02-23-2012, 12:22 PM #2
CelicaSupra.com Member
- Join Date
- Mar 2011
- Location
- Nashville, TN
- Posts
- 107
Pillars being the two post on the front of the vehicle that support the roof. If so yes and do you also have the clips? With Speed, Wind and Age both mine have blown off. Well that could be said of a lotta things in my life. Biggest question is the plastic hole in the bottom to screw them down still attached?
THANKS
02-23-2012, 02:09 PM #3
Member
- Join Date
- Mar 2011
- Location
- richmond virginia
- Posts
- 31
No the b pillar goes between the the corner glass and window
02-23-2012, 06:54 PM #4
- Join Date
- Mar 2011
- Location
- Nashville, TN
- Posts
- 107
I also need an interior piece. By pillar are thoes the things in the front that supports the roof between the side windows and the windshield?
04-04-2012, 03:08 PM #5
Think of the pillars as posts that hold the rood up. Moving from the front to the back the first pillar is called the “A” pillar. That is the one that frames in the windshield. The second pillar is the “B” pillar. This is the large pillar that is right behind the doors. On some cars with more supports you just keep lettering them out as you move back. In the case of this part for sale the “B” pillar in question is the one with the glass Supra logo on it.
10-16-2012, 08:24 PM #6
'79 through '81 Mk1 Supra, exterior B-pillers trim panel.
Marty, did you get a set of exterior A-piller trim from me? I had some.
Are you still in need of any of the black trim covers? Or is a missing clip needed for yours?
Any one else missing the plastic trim piece by the windshield edge?
Are you missing any of the metal windshield trim or the corner piece that locks it together?
This original clip is used to secure the exterior A-piller trim together with the windshield trim to hold both down.
When clips are used and secured correctly it holds down the A-piller cover and locks the metal windshield trim together at the edge. All held together with just one screw.
The hole on the black plastic trim can be broken off. If this clip isn't lost.
With this clip on as it was designed, the A-piller trim still will be held on secure.
10-17-2012, 10:28 PM #7
PM sent
