Results 31 to 39 of 39
Thread: Killed a 380hp 7m'd MK2 Supra...
03-31-2012, 12:23 AM #31
CelicaSupra.com Member
- Join Date
- Jan 2005
- Location
- Atlanta
- Posts
- 528
Hey William,
A lot of diagnostic work was done to resolve this issue. Our timing tables are very similar. The turbo has been tried on a 7MGTE that was practically built for fast spool and there is little to no difference. A .82 A/R does not seem very suitable for the street on a 7M no matter what you do.
-John77 Celica: GT coupe (SOLD)
82 Supra: L Type Terra Cotta Hardtop 7MGTE
82 Supra: L Type Terra Cotta (PARTS)
83 Tercel: 4WD (SOLD)
91 Mercedes 300SEL: Eternal Project
95 BMW 318TI: Daily Driver
04-03-2012, 04:10 PM #32
i didnt se that you had done any timing change as of yet so figured id help out. as for a street turbo, id drop the 82ar down to a 68ar if your after spool. asuming it is a single scroll turbine housing. if it is a twin scroll housing, i highly recomend switching to a twin scroll manifold. there is an ebay manifold that can be modded for twin scroll pretty easily actually. has a divided outlet, and 2 wastegate pipes that merge into 1 for a 44mm wastegate. id simply cut them before the merge and route them as needed and run two 38mm vband wastegates. that or possibly install one of the ps quick spool valves if you have the room and dont want to do any fabrication on a manifold.
william
04-03-2012, 04:56 PM #33
^He's running a LIPP bolt-on style turbine housing on factory manifold...
...no changing of the AR possible.
--billyMBlue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
04-05-2012, 04:26 PM #34
i didnt realize those LIPP turbine housings were that large. wierd. thought they were more like a 70a/r. i guess its time for a ebay turbo mani, wastegate, a real t4 turbine housing for the turbo in a 68a/r, and then a custom dp and tweak the hot i/c pipe to make it all work.
william
04-30-2012, 11:04 AM #35
John and I never got a chance to line them up this weekend...
...but I did get a chance to line up with another 7m-gte 61mm-equipped car.
Video and story pending...Blue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
06-21-2012, 03:12 PM #36william
06-21-2012, 11:44 PM #37
Laziness...
BillyMBlue 82 L - Black 83 P - White 83 P - Brown 84 T - White 85 P - Blue 85 GTS
06-22-2012, 07:24 AM #38
take some nodoz with a cup of coffee and get it posted!
william
06-22-2012, 11:01 PM #39
*posted from the beach 4hrs from my gopro and all containing video.
